idosubaru
344
0303 is cylinder misfire and cause of poor running most likelY. I would think the 0420 has a chance of going away if you fix the misfire. If you've been driving along time with it running poorly the converter May be compromised. Install new NGK plugs and NGK or subaru wires O2 sensor - install an O2 sensor extender, they're like $5 on eBay. 0420 is one big debacle of a code. It's benign and causes no drivability issues, the ECU doesn't even look at it. You can disconnect the rear sensor entirely and it changes nothing, car will run just as normal as before.
- 12 replies
- 2000 Outback
- P0420
(and 3 more)
Tagged with:
The original XT6 keys are unique and have a built in light. Some people like them but they're obviously old and unavailable last I checked. I have a few used ones so why not gamble and have them cut to a different car and see what happens. I've got nothing to loose. Multiple times I've had warn keys work in two different XT6's. And sometimes I've had a key work in just the ignition or just the doors or start the car and could be pulled out while driving. seems like the lock cylinders are somewhat forgiving. Anyone ever try it?
Connector is up inside the body side of the vehicle. Pull the rubber grommet/conduit/cover that you see right now. It just pops out of the hatch and body side of the car (basically all Subaru doors and hatches are like this). Then you'll see the wiring. pull it until you get to the connector. You can swap doors, trunks, and hatches by yourself but it's super awkward, probably a terrible idea (drop, dent, scratch, etc). Having a helper makes it a cinch just because it's awkward, not because it's hard. Holding a door or hatch while trying to turn bolts is pretty fun (not), i just did one this week. don't recommend it unless it's a last resort.
i'd get a Subaru FSM for that. usually the easiest repair is to just swap an entire rear hatch. it's like a few bolts and unclip the wiring harness, can be done super fast and easy. i can appreciate wanting to use what you have on hand - i'd get an FSM online and check the SUbaru procedure there. i got my 2002 outback FSM free on line, a google search will eventually land you on a place that isn't click bait. LOL
i don't know anything about crosstek space in the back, but a genearl comment since you brought it up - might want to have plenty of room to grow into. pack and plays, strollers, bags, gear, bikes, etc. if you travel, go places, parents live out of state, will have another kid in 2-3 years, enjoy hobbies then get as much space as you can. it's nice to have room for strollers, pack and plays, kids gear, or sit one or two people in the back to go with you places. the smaller Subarus can be really tight to fit two people in the back with a car seat or one person in the back if you have two car seats. this includes the products you buy: small car seats are much more convenient than bigger ones (they can still have top safety ratings). our first car seat we didn't pay attention and it was a monster and cumbersome compared to later seats we bought.
+1 on the MAF - i've seen those not cause a check engine light even though they're problematic (stalling, no start, poor running) swap in another idle control valve or clean your existing one check fuel pressure why was the cam sensor unplugged? if you plug the cam shaft position sensor in and drive it a week - you get no check engine light?
ah - if you're just doing it twice - to get the car there and back. that's not a big deal. if you were making 500 mile road trips every month - then it sounds like a bad idea. correct - H6's all have automatics, 1988-1991 XT6's are the only stock Subaru 6 cylinders with manual transmissions (my daily driver is one of those) there's no appreciable difference between 00-04 and 05-09 outbacks in terms of towing. the H6's can overheat towing heavy loads in summer and steep grades. seen multiple H6's do it. the extra power is nice - but the biggest weakness remains - undersized and cooling. but you sound like you got that noted to pay attention and address if needed. if it's flat and you're not towing in 95+ temps you'll likely not have any issues anyway.
'88 GL10 FWD to 4WD conversion?
idosubaru replied to Wallis_93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
MR radon did it and documented it at subaruxtz.com -
Usually easier to buy what you want but it can be done. MT to MT? AT to AT? MT to AT? AT to MT? Manual or automatic car? Manual of automatic conversion transmission? Need: Transmission Driveshaft Shifter mechanisms Entire rear suspension - crossmember, diff, axles, knuckle assemblies - and probably gas tank for 4WD clearance? Rear struts are different but interchangeable - they have different mounting positions so might give the car a rake if you don't swap in 4WD strut assemblies. If AT to MT or MT you'll need pedal assembly If MT to AT you'll need a radiator or dedicated cooler for the fluids with Not necessary but Ideally you also get or may want: Center console for interior aesthetics Instrument cluster cruise control is auto/manual specific, if it's equipped, swap the controller. -
Ohio is a much different market. i go to Bushwick's area once every month or two. up until a few years ago i would go an entire weekend without seeing a Subaru there. that can't happen even with a short commute here. In a dinky town with only 30,000 people we have a Subaru dealer (another 30 minutes away), Subaru only used car lots, Subaru only junk yards (though they are challenging to deal with), and Subaru only mechanics/shops. Akron is 200,000 people and Canton 70,000 people - that's an order of magnitude bigger than where I live and if anything like that exists - it's rare. My relatives have bought two Subarus recently and their 20+ year mechanic in Canton said he wouldn't work on them because he doesn't know them. A mechanic here would get funny looks with a response like that here. Subaru's can be really cheap there on craigslist but rust issues beware. i see gaping hole rear fender cars and trucks frequently in ohio, that doesn't pass PA and WV state inspections, that changes the market too. you can get $3k and $4k for later 90's Subaru's here - depends on time of year, condition, and mileage. we have yearly inspections so they need to have limited rust and pass those inspections for the next few years to command a good price. i sold a 99 a year or two ago for $4k+. i can't imagine that happening in Ohio.
check fluid level first thing - where is it? read the check engine light and post the code. read owners manual and see what it sas about the AT light. check it again and count - most likely it is blinking 16 times if it's doing it at start up. check the AT pan and make sure it's not dented? most common AT issue is duty c solenoid.
Check your front differential oil. That's unlikely because you'd probably also have some noises but given the cost I'd check just to be sure. Are the inner axle joints green, like this? http://img.photobucket.com/albums/v238/mschmidt/DSC05728.jpg That picture is from underneath. They can be seen from peeking around the wheel, but with good lighting you should be able to peer through the engine bay too. Post a picture here if you're unsure. If they're not green - then it's likely aftermarket axles causing the issues. Aftermarket axles have all sorts of issues - i've even seen brand new ones blow apart in 50 feet after replacement...little balls rolling all over the ground and everything. Noises, vibrations, you name it. of course there's plenty of good ones but they have a rather high failure rate. Maybe they were run with broken boots for a long time but that seems unlikely if we just make guess from what information you've given us. If it is axles, but used axles and have them rebooted with Subaru boots (aftermarket boots only last 2-4 years): www.car-part.com for cheap used axles everywhere. FWE in Denver sells excellent quality axles if you want an off the shelf option.
i meant pay someone else to do it. $400 EJ22 and $400 to install it - and $300 for the car and you can end up right around the same price of the one you're looking at but have some more control over it and end up with a far better, less risky engine. although you're probably limited in engine selection down south. www.car-part.com 1995 legacy or impreza EJ22 from an automatic is ideal any EJ22 1996 - 1998 is also a possible candidate
yeah that's basically what 2000 Impreza's came with - so that makes sense, it's the easy fit. Here are the engines that are plug and play: 1999-2001 EJ22's (they're rare, sometimes expensive/hard to find - probably why someone installed an EJ25 - there's far more of those). 1999 Forester or Impreza EJ25 2000-2004 EJ25 two points of note: 1. swap the crank sprocket and drivers side cam pulley to make sure. there's two different trigger patterns and you want to keep the same ones to the vehicle. techincally you can check them and count the triggers on the back side or assume auto and manual are the same as a guide - but it's an easy work around either way. 2. you'll want to verify what exhaust you currently have. EJ25 exhaust manifold is dual port. EJ22 exhaust manifold is single port. if it's a complete EJ25 engine - then you'll need to swap exhaust manifolds to use an EJ22. if it's an EJ25 short block with EJ22 heads - then you'll have a single port exhaust and need to use an EJ22 or get dual port exhaust to match the EJ25. you'll need to look and check - the EJ25 and EJ22 heads are interchangeable, same intake mainfold, so someone could have bolted the EJ22 heads to an EJ25 block. and even 2005+ engines should work too - plug and play but the variable valve stuff will just sit there doing nothing and they're more expensive so usually not a compelling fit.
