Axle swap interchangability between platforms - 5mt swapped H6 outback
idosubaru replied to punx2400's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the sundials are different- the stubby shafts on a manual trans don't pull out of the front diff from the outside like the auto's.
New to me 2001 outback 2.5 manual
idosubaru replied to hush777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're a solid platform. Interference engine so I'd immediately be installing all new Subaru or Aisin timing belt, tensionser, pulleys, and water pump if it's in good enough condition to warrant that. You don't really want a 25 year old lower cogged idler - they are by far the most failure prone item on there. If minimalist is preferred: replace the timing belt and lower cogged idler - those are the two parts most likely to fail. The others don't fail often anyway and often times give you warnings the others don't. After market belts and pulleys aren't as good, I've seen the pulleys fail and the included tensioner bolts shear. While you're in there it's not a bad idea to reseal the oil pump (anaerobic sealant, one o-ring, and the crank seal) and tighten the backing plate screws - more than one are always loose.
Stumped on my highschool daughters first car - 2008 Legacy can't go up hills and has no power
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. We are thankful. Tuition, dorms, meals, all covered. It was multiple round of interviews over the phone and in person. Quite a bit more effort (and driving) compared to all the others submitted online or write an essay, etc.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXResolved, replaced both converters. Thanks Brusbrother. Got this car from Georgia for my daughter, so it's rust free, I'm sure you can appreciate that. Concern is what caused this and hoping it doesn't destroy the new ones - oil level was increasing and bad mileage, pretty sure running rich. Found and replaced one cracked injector while chasing the clogged converter issue. Time will tell. Runs great, looks great, ready for college next year, she got a free ride at her top private school pre-med and was the first player in school history to be named first team all state twice as a junior and senior. Not bad from a rural public school with very poor academic options. /end proud dad brag
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOddly I didn't get one tiny particle to come out by doing that. Interesting suggestion, doesn't seem like enough power but I'll be taking it apart again - ordered a $80 ebay exhaust manifold (if you've seen the 05+ manifold pretzels that's a crazy cheap price) to have some options. I'm wondering if the clog is in the header (i think it houses the catalysts), the mid pipe, or the mufflers or more than one. Hesitates around 5,000+ RPM's/flooring it (which is sometimes helpful on a steep mountain grade but others unecessary - but makes me thinking something is still clogged. Otherwise it drives totally normal. I wore ear protection but should call and apologize to the neighbor - her horses went tearing off towards her house.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXConverter ended up being the problem - just took a minute to warm up and relearn I guess, Runs perfect without the exhaust connected
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou were right! Thanks man! Now...this newer 05-09 stuff has the curved catalytic converters right by the engine, they're going to be much harder to gut....
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCat converter - seems fine, disconnected exhaust and still runs just as bad. Fuel filter is in the tank, can't replace - i'll have to pressure test or pull the fuel line and see how well is sprays out Ill get a new oxygen sensor later.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2005-2009 doesn't have a fuel filter, or it's "in the fuel tank".
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year/model engine and did you have check engine lights in those cases? Max 4,000 RPM with no power for hills but otherwise drives without hiccup or stalling is oddly specific, I doubt your symptoms were identical. It would be drivable on flat land, but can't get up hills.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't seem to be the oxygen sensor. I'll try disconnecting the exhaust in the morning.
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh wow my good sir, wasn't considering the exhaust at all. That would be awesome. Aye aye captain - I rammed one out of an XT6 20+ years ago. It's not drivable enough to accrue miles and calculate gas mileage. Yeah this is a new sensor but it's the style that comes with bare leads you splice the old connector onto - and I do'nt trust that it's wired properly. I'll check those.
Engine starts and idles fine, can't tell anything is wrong until you go to drive it. It's severely underpowered. Floor it and it very slowly accelerates, sometimes can get up to 40 mph on flat or downhill. It won't even make it up a steep mountain, so it's undrivable around here. New headgaskets, timing belt, and compression tested fine so I assume the timing marks are still good, but Ill check them tomorrow. Drove fine for 3-4 months after the HG then gradually got worse over a week before it became undrivable. The oil had significant coolant/water mixed in with the oil before I did the HG's - could the valve control solenoids be damaged by that? P0038 front O2 sensor code - car does the same thing with the sensor plugged in or unplugged. Will these run without a front O2 plugged in? Maybe the 02 sensor is bad. It has a 4 wire Bosch O2 sensor with the old plug spliced on - does anyone know how to verify the wires are correct? It had a cylinder 3 and multiple cylinder misfires - I replaced the plugs and wires with subaru issued goods, and the codes for those went away - but the CEL did flash last night on a test drive then quit...so maybe it's still doing it intermittently. Any suggestions.....
idosubaru replied to punx2400's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe stubby shaft out of the 00-04 trans pops right out, it's only held in by a circlip and readily pops out. Put the axle on it with roll pin and yank or use suitable tool to pull it out. Put the 00-04 stubby shaft into the 00-04 axle and you then have an axle with a stubby inner shaft. I'm not positive it fits into the later 05+ trans but I think they do and it should be really easy to check.
2012 Tribeca Tans codes P0710 and P0700
idosubaru replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the pan isn't dented underneath and ATF filter isn't nearly 20 years old and stuffed? Do a drain and fill and see what comes out of the pan? Was it a 1710 code or 0710 code? 0710 isn't showing in the 06 Tribeca FSM I have, they go from 0705 to 0712, maybe 2008 is different. Here's what the FSM has for P1710: P1710 TORQUE CONVERTER TURBINE 2 SPEED SIGNAL CIRCUIT 2 MALFUNCTION
06 baja drinking oil
idosubaru replied to bajablasted06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's wild. Glad you figured it out.
Can an injector leak this much?
idosubaru replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, yes these are just simple straight through side feed. Maybe comments people made about turbos had me confused, it didn't look like these could leak. Thanks
idosubaru replied to bajablasted06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost are non turbo. How many miles on the block? Leak down and compression tests? Check the PCV valve system for blockage? Seems like a long shot but if you're confident the valves and rings aren't it.... Was it burning oil before you replaced the rings? After you replaced the rings did it burn less, more, the same, or can't tell? When rings were replaced were there any signs suggesting which cylinder was the culprit? Did you replace all the rings? There's only two ways for oil to enter the cylinder: valves and rings. Rings are most common
2005-2009 Outback XT reviews?
idosubaru replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGreat choice, the turbo's with age are highly problematic. Gas turbo's in general are be design more complex and don't age well. The turbo's fail, replacement turbo's often aren't good quality, any overheating or low oil situation quickly plants the seeds for catastrophic block failure. And by this age it's not uncommon for one to see oil or overheating issues at somepoint in the past.
2018 Outback - front axle - alignment ?
idosubaru replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood luck! I'm from Carroll county, was at the Lock House Museum close to you in the spring or last spring on the way back from Philly.
How to test for leaking injector? How do they fail, will it still leak internally if the harness is unplugged?
2008 Legacy - oil level seems to be rising and smells like gas and thinned out, running poorly. No check engine codes. Can I unplug the electrical connector to the injector as a test? Or do they just internally whether they are plugged in or not?
idosubaru replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJohn in KY - you still on here, I know I just talked to you recently person to person but thought Id reply to this old post. Did this end up being an injector issue or oring issue? I have high oil level and it's also running poorly in a 2008 legacy EJ25. Orings can cause an internal leak into the cylinder? How does that happen? I have orings on hand, but not injectors....
idosubaru replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour biggest potential (though unlikey on a car this new) issue will be trying to get the ball joint out of the knuckle. It will all depend on how much rust/salt that thing has seen. The guys out west and down south don't have to worry about that and can pop ball joints all day long. The ball joint just pops out. Up here....sometimes they pop out, sometimes they don't. I've ripped t(metal shards and all) the ball joint shaft right through the actual ball itself which was left rust welded into the knuckle, then you're spending a lot of time chiseling/drilling to get the remnant of the ball joint outer casing separated from the knuckle housing and you'll need to replace the ball joint. Good chance a 2018 isn't that bad and comes right out...but if you ever do experience a rusty ball joint you will curse everyone who says "oh just pop the ball joint out" and realize they often live down south/west or are dealer guys only working on new cars under warranty. Are the current axles bad, these newer axles often run a lot of miles without issues and almost never fail. An aftermarket axle may very well fail before the originals with 200,000 miles. In rust prone areas many of us avoid the ball joint and just undo the lower strut mount bolts to replace an axle. The top bolt impacts camber, so you mark the HEAD (not the nut) of the bolt relative to the knuckle housing and make sure you install it exactly where it was before you did the work. EA81, EA82, ER27's are all front parking brakes, so yeah nothing newer than 1994!
Quickest possible question regarding 2001 3.0 H6
idosubaru replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOriginal engine? 01's and some 02's were notorious for timing chain noise. I believe due to tensioners and they have jumped timing before. I've seen failed tensioners and guides, never a failed chain though I'm sure anything is possible.
Anyone ever run a 2005+ EJ without a timing belt cover - I have a question for you
idosubaru replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guy. The tensioner does look suspect - the small pin that pushes against the bracket to create tension looks somewhat mis-marked like it's not contacting evenly. I'll go ahead and replace that. It's OEM - I'm about to restart it with a new belt, I'll see if I can see the tensioner flopping around at all. I had a 1997 EJ22 tensioner (same one piece style) do that - I guess lost hydraulic pressure and was slapping a bit until it warmed up. Though I don't recall it wearing the belt weird. I'll try to post a pic. It's very odd - like a worm ate through the top of the belt in spots...I'm exaggerating the car was still driving but it seems like anything pulley related would simply be straight not curved and wiggling across the surface.
