apintonut
Everything posted by apintonut
  1. Its just a pile of scrap now
  2. well he red 86 is less of a car now
  3. lol, its all good! yah my spelling and typing is atrocious. However, I dont let it hold me back in life It also falls low on my life improvement list.
  4. Makes me feel lucky to be part of an anti negative group, that call you out on minute issuers of proper grammar in this informal setting. Well it WAS. Thanks for the status change update monstaru.
  5. already came to this conclusion
  6. ill look at it but im putting it off till i have more money to put into it im building a front engine buggy right now and will build this one later
  7. I. Dont know what the wheel base of a stock dl is but if u had to shorten the wheel base how much shorter would be ideal?
  8. the mustang 2 (pinto is the same) i have the saab is somthing i was going to use for another project so im familiar with it (and think may fit a subaru axle)
  9. side side note i am very fortunate to own a press if u dont u can use a GOOD "C" clamp or get a ball joint press from o'reily auto parts (free rental with deposit)
  10. ok well ive now done it its easy if you have done a subaru before (side note ive done about 100 ujoints but ones that are supposed to be changed) THESE ARE NOT DESIGNED TO BE CHANGED!!! however that being said, it can be done. (first lesson) dont bother about the sake points just press right past them. (step 2) press ujoint 1 way till it stops with just one socket in the to that is .5mm smaller that the ujoint cap. (step 3) flip and repeat this un-dose the stakes on both sides. (step 4) then smack ujoint with hammer in first direction (not caps) then grab the first cap with vice grips and twist out. if u need help from there well.......
  11. ok then use some ones stock take offs till you can upgrade or use saab 900 from ~1989
  12. i was thinking mustang 2 upper control arm you can get tube ones from speed way cheep
  13. they sell ujoints that have internal c clips as replacements
  14. i would like to take the ujoints out of a dl drive line has any one done this/ there is no c clips? i need to make a short drive line for my rail
  15. sorry i didnt catch how the taper of the ball joint was mated to the subaru knuckle?
  16. back on the soob kart, well i unpiled it! still doing lay out. have alot of drilling of holes and notching tubing
  17. i have a jeep and bronco however they closed down all the wheeling out here in ravensdale so i wanted something i can tow out to wheel so if i brake it, put it on the trailer and go home. so i started to build a rail but wanted a 4x4 so i chose build a rail with subaru parts in part due to youtube of nw off road and look forward to bringing it out to play
  18. They r both doing well just had a close call on losiing both. Ultra sound indicated that baby was 8lb tuurnned out she was 9lb 14oz and she got very stuck 1/2 way
  19. well no updates ive been staying at valley medical center for almost a month now but wife is released and my new daughter hope marie lentz should be released this week!!!! then ill get back on the soob kart
  20. Well bring blue over and well test run them
  21. Got some differnt tire Think they might get traction Only 27" tall 27x11r14
