2
Posts posted by sumoco
Thank you been wanting one for a while.
I was driving my buddy to Colorado and decided to make a trip up to Jackson hole
Never would I of thought I would think of an ea82 as sexy. But it's just so shiny
So I've had this thing for a while now, done some work on it but nothing to extreme. Figured I should start one of these before I start to get crazy on it though.
Couple days after I bought it
Going across the country a couple days later
I then swapped over my set of re drilled hubs, added some 2 inch spacers, got a new set of tires from the schuwab, found a canopy( which is for sale if anyone is looking ) and jacked my shocks and torsion bar as high as they would go. A temporary fix for the rubbing.
I also added some "sweet" electrical tape racing stripes( I know you're all super jealous of those)
Soon I shall be putting a 6 inch lift, a d/r 5 speed and an ej22.
Awesome I will try to jack up the tranny and put it in gear once I get back
No, the only time I have ever put an engine back into a car was on my 66 ford and a forester that i changed the clutch and flywheel on.
Basically what I'm saying is any advice is good advice
The bottom studs on the engine are my main trouble
I've been trying to get my engine into a hatch I just recently acquired for over 3 hours. No matter how much I twist, re level or slide it will not meet up with the transmission. Am I being stupid or is there something out of my control.
The car is an 80 ea81 series hatchback that has an ej bell housing with ea push button transmission innards.
It seems like I need to remove the front clip to get it in, but am not sure if that is even an option in this car.
Seriously, that thing is amazing
alright, so final decision. this version of the project is dead. the next time i get working on this thing, probably in 2 years after college, it wont really be a subaru anymore. just a 78 brat body on a custom tube chassis with toyota axles, 4.3 chevy v6, th350, dual transfer cases, 40 inch tires, etc etc. i know, big dreams, but thats whats going down! just thought i'd let you all know this thread is dead for a couple years.
Aw that just made me so incredibly sad, your brat is one of my all time favorites. Hopefully some schooling will change your mind but either way it will still be a beachin brat
I must have been special because they touched my 6 lug swapped brat. Never told them it was a drilled hub though
And a bag of potato chips my friend
Awwwwwwwwwwwwwwwwww heeeeeeeeeeeeeeeeeeeeecks yeah
With some work you could put an ea81/82t in, but at that point you might as well cram an ej22/20 into it, pretty sure you have to cut frame rails but it's not extremely intense fab work
If I'm making an ea81 lift do I need to offset the top and bottom since it isn't a triangle?
Still trying to find time to slam my ej22 into it, been slammed with work. Going to try to bring it up to wcss
RWD!!!!!!!!!!!!
Do you have a build thread for that beauty?I know this post is 3 months old and I often go months to years without posting but this guy has no idea what he is talking about and his pontificating shows that he has never built a single part.
Any kind of lift is a compromise, you can throw a 18in kit on a full size truck and that solid axle is still the exact same height above the ground, you can put 2 inches of strut lift on a Subaru and gain 2 inches at the diff. The only thing beyond that that gains ground clearance from the axle of a live axle vehicle or the centerline on an independent suspension vehicle is larger tires. A lift kit alone is only part of the total package. And ground clearance is gained and measured in different places. Lifting the body overall IS effective, it gains you improved approach and departure angles which is an important part of offroading, as is ground clearance from the body to the ground.
Here is an example of ground clearance I gained on this BRAT build:
Keep in mind that my oil pan is another 8 inches ABOVE that crossmember which has about four times the ground clearance of the stock vehicle. And gee how did I do that without portal axles (which I would totally go for if there was a model out there that didn't need the CVs running in the opposite direction and offered meaningful reduction)?
That may be my favorite brat that I have ever seen. Good show sir. Good show.
Nope it's a white one from Yakima Washington, it's covered in stickers( in the process of removing them) and has the rear windows tinted
So I just bought a 80 hatchback that was converted into a rwd drift machine. The dude before me had taken the innards from a single range loyal tranny and put them into an ej22 bell housing, chopped and welded the front axle nubs and lowered it so it sits about 5 inches off the ground. It's about to have my ej22 dropped in and we shall see how well it actually handles
Thank you very much, a lot of people are very rude when you ask them about things like this
Did you ever fix this issue? I'm having the exact same problem on my 96 impreza outback
Of course I want it but I'm already balls deep into my brat and don't have the dollars for this beaute
NO!! you must finish this thing it's too good
1st roadtrip with 82 brat- 2000 miles :-)
Posted
Hah your brat looks just like mine when I went across the US
