Everything posted by natetru
auto tranny question
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe fluid is absolutley clean...but i will pop radiator cap and check it also. i put a 4 inch lift on the car within last 50 miles, so i assume when i dropped notor/tranny i stretched the line that split... it is along driver fender near firewall....where rubber line connects to hard line.
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you very much....any additives reccomended for subarus?
1997 legacy gt wagon while sitting in my driveway checking for coolant leaks after a radiator swap, i start seeing tranny fluid start to drip, then run, then gush and spray ( about 20 seconds total while i look for source) then i see the rubber line back towards tranny has split..... my question is, i lost 1-2 quarts i guess. should i drop the rest of the fluid out and change filter since it is needing refilled. or am i better to leave what is left inside and just refill....anything else i should do while its down for this issue/ thanks in advance......
2004 baja turbo
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you sir
2004 baja turbo
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok...the motor is out, and i believe heads were removed before he decided he doesnt want to get into it. we have already agrred on a price, i think it is absolute steal....under 1000......plus another 3000 to geta new motor in it....id be in car for 4000
2004 baja turbo
Hello, I am looking at buying a 2004 Baja turbo. Motor had an erratic miss and would pop dipstick out of tube......he pulled the motor thinking a head gasket was bad and never did anything with it.....my question, is what is a safe amount to purchase it as is......please serious answers.....thanks
1997 legacy gt wagon lift
just got it out of the garage. forester struts and 4 inch lift.....has some vibration in driveline so need to look at the carrier bearing and ujoints.....then will need diffrent offset on wheels so i can go larger tires. right now the rear is about 1 inch under the perch...has 1.5 inch wheel spacers but still doesnt clear the perch by about 3/4 inch out so should be able to fix with differnt wheels.......
SJR Full time
scott, thank you very much for taking my call this weekend. you sir are a good guy.
1997 legacy gt lift question
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwe will see how this goes.....got the stuff, going to attempt to get it complete and back on the road by monday.....wish me luck
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have the block steel sourced...gonna look at the pipe size for the strut lift today.
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, center of the car, meaning towards the opposite side....not the center as in between front/rear
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXawesome. 10 degrees from top angled towards the front of the vehicle remaining parallel
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX@gloyale the 10* you add into a 4 inch lift, is that 10 towards front,rear,inboard or outboard. i appreciate your help a ton. so, if i call the top of the mount 0* which direction should the angle go? thanks again, nathan
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr is it "best" to save until I can purchase the rear set from sjr
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks, would it be equivelent to the angle that the fronts are angled?
I have a 97 legacy gt wagon. I have the front half of a 4 inch sjr lift. I can not at this time afford to purchase the rear half. but I have access to all the equipment needed to fab the rear myself. my question is do you have to adjust angle of the REAR STRUT MOUNTS like the angle of the front strut lift mounts are, or are they just straight(square). thank you all for the info in advance.
1997 Legacy GT replacement coils do not fit.
natetru replied to RedGTLegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi also have a 97, built in October....recently did headgaskets. the valve cover seals were incorrect and after going thru some hoops found I had valve covers from a pre transition motor....so, look up the part for a 96 and see if the pic matches whats on your vehicle
98 legacy outback wagon... sits too tall, need some ideas
i have a complete set of legacy wagon struts and springs i will sell for 150 plus shipping. i removed to install forester struts because i wanted to be taller..... ok, this post is 1 year old...duh
SJR Full time
delete
SJR Full time
kinda was asking if there was angle correction on the rear strut mount like the front has or if it is square
SJR Full time
double post
SJR Full time
what kind of angle correction is needed for 1997 legacy gt rear 4" kit?
LIFTS! 2000+ Outback, Legacy, Baja HIGHGUYS!
subframe spacers
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you send me a pic of your ride.... i would greatly appreciate it
subframe spacers
natetru replied to natetru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have forester struts and one inch spacers, any one recommend both or just struts?
