natetru
Everything posted by natetru
1997 legacy gt wagon while sitting in my driveway checking for coolant leaks after a radiator swap, i start seeing tranny fluid start to drip, then run, then gush and spray ( about 20 seconds total while i look for source) then i see the rubber line back towards tranny has split..... my question is, i lost 1-2 quarts i guess. should i drop the rest of the fluid out and change filter since it is needing refilled. or am i better to leave what is left inside and just refill....anything else i should do while its down for this issue/ thanks in advance......
just got it out of the garage. forester struts and 4 inch lift.....has some vibration in driveline so need to look at the carrier bearing and ujoints.....then will need diffrent offset on wheels so i can go larger tires. right now the rear is about 1 inch under the perch...has 1.5 inch wheel spacers but still doesnt clear the perch by about 3/4 inch out so should be able to fix with differnt wheels.......
scott, thank you very much for taking my call this weekend. you sir are a good guy.
I have a 97 legacy gt wagon. I have the front half of a 4 inch sjr lift. I can not at this time afford to purchase the rear half. but I have access to all the equipment needed to fab the rear myself. my question is do you have to adjust angle of the REAR STRUT MOUNTS like the angle of the front strut lift mounts are, or are they just straight(square). thank you all for the info in advance.
98 legacy outback wagon... sits too tall, need some ideas
natetru replied to mightGETaSUBARU's topic in Suspension
i have a complete set of legacy wagon struts and springs i will sell for 150 plus shipping. i removed to install forester struts because i wanted to be taller..... ok, this post is 1 year old...duh -
delete
kinda was asking if there was angle correction on the rear strut mount like the front has or if it is square
double post
what kind of angle correction is needed for 1997 legacy gt rear 4" kit?
LIFTS! 2000+ Outback, Legacy, Baja HIGHGUYS!
natetru replied to Gloyale's topic in Products for your Subaru
