bushytails
Everything posted by bushytails
  1. My guesses would be vacuum advance or mechanical advance aren't working, or you're setting it with vacuum advance connected or at too high of idle speed. You should set the timing with the engine idling at normal speed (no more than, say, 700rpm) and with the vacuum advance hose disconnected. After setting it at idle with vacuum advance disconnected, rev the engine up and verify timing advances with engine rpm, then apply vacuum to the pod on the dist using a hand pump or a manifold vacuum line and verify timing advances.
  2. As long as the springs are holding it tight, it doesn't matter what they are. My car has generic dorman ones from the auto parts store. Did you make a new bracket?
  3. It'd read somewhere between 2 and 100. I remember when ford fixed complaints of low oil pressure by replacing the gauge sender with a switch and resistor, so the gauge always read 2/3rds from 2psi up...
  4. Just run the pin you have. The wear will be taken up by the adjustment at the release fork.
  5. You could narrow the subframe... you could add fender flares... orrr.... you could cut the brat down the middle and add 6" of sheet metal!
  6. Since you're probably going to be fabricating your own, just make it fit whatever bolts you want.
  7. Here's two pics of an extremely mushed 4-speed d/r one, and a non-mushed 5-speed d/r + ej car: https://imgur.com/a/bUgpkRj I'm guessing your bracket is missing, if there's nothing like it hanging down.
  8. That looks right to me. The "gap" will shrink as the donut wears. There should be a bracket on the back of the transmission that the exhaust rigidly bolts to, not a hanger. This is a little newer, but shows how it works: https://www.subaruoutback.org/attachments/560913/
  9. My cables start breaking strands at random points, then snap... just shitty aftermarket cables, combined with my doing a lot of city miles every day.
  10. I think you meant to quote someone else?
  11. The EA81 AC fan circuit is a satanic unholy mess that includes, among other things, whether the headlights are on.... What vehicle are you working on?
  12. I hate doing clutch cables. I've been tempted to stick in an ea82 pedal rack just for the easier clutch cable jobs, which I seem to do every year or two...
  13. No, they do not. And haven't for a while, so the supply of old stock has dried up. And lots of us need struts...
  14. If (and until someone tests a pair, that's a big if) the renault ones are indeed a good fit, coilovers for that vehicle would also fit, like https://www.apmotorsport.co.uk/product-page/megane-2-rs-ast-5100-1-way . But they're waaaay out of my budget, so I haven't been looking at anything similar. If searching, be warned most seem designed to lower the vehicle, because non-subaru owners are weird.
  15. I really should be in bed. lol. But my car also needs struts, and I keep looking them up... I found what may be an exact-ish replacement: Front struts for a new Renault Megane II. Wtf, really? lol. 44.5mm diameter, 545mm/21.46in extended length, 357mm/14.06in compressed length. According to https://www.ultimatesubaru.org/forum/topic/157099-front-struts/?do=findComment&comment=1313458 , a 4wd strut is "Extended Length 21.25" Collapsed Length 14.00"". Spring diameter looks similar, bottom lock bracket is... different, of course, but may be able to be bent to the right place. Haven't seen specs on the top nut. Fairly cheap, but not available in the US, due to said Renault vehicle never being sold in the US. Some part numbers: BILSTEIN 22-132390 KYB 333718 KYB 633718 MONROE G16387, though the monroe comes up as 2" shorter than the others. The KYB 633718 seems like it might be the premium version, and the 333718 the maybe better excel-g version, not sure what's really different... you'd be installing them with all the subaru top hardware, of course - spring perch, bearing, mount. Want to buy a pair and let me know how they work? lol And now bed. really.
  16. I'm finding conflicting information on whether early '80s bmw 318i/325i struts might be somewhat compatible. Possibly also some newer bmw models. Will need to do more research when not falling asleep.
  17. I just braved the mosquitos to check, and a well-used 1984 ea81 gl wagon 2wd strut measured 44.62mm at the end, so probably 45mm nominal. a 50mm sambar strut is too wide as well as too short. And, of course, 45mm seems to be an uncommon size...
  18. Stock ones look a *lot* shorter... There's tons on ebay, like https://www.ebay.com/itm/167537573301 , and they look like half the length...
  19. Do you have a plan for shorter CVs? The diffs are indeed essentially the same. One's probably a 5-bolt R160 and the other a 1-bolt R160.
  20. A sambar is a bit lighter than a brat, so the springs might be too soft. They give the lower tube diameter as 50mm, no other specs I can see. Email? You also might try finding some used/junk sambar parts and seeing how close they are to bolting up.
  21. Drain coolant, pull a heater hose, plug off one end, hook the other end to compressed air with a valve, slowly let some in, listen for where it's hissing. If it's hissing at the carb, or out a spark plug hole...
