2
Everything posted by 3Pin
I have a quick question for you all. I have a 2003 2.5 outback automatic trans with a bad motor. I also picked up a 2001 2.5 Outback motor with an automatic trans that has a nice running motor but a rusty body. I was going to swap the 2001 into the 2003, but I hear it is not an exact swap. Can someone help what what is different? I have read that the cam and crank sprockets are not the same and that possibly some sensors need to be swapped for the 03 motor? Anyone? I have the motor out of the 2003 already.
Had a Tribeca....not the best car Subaru has ever made. Bad mileage, poor HP if the 3.0. Limited productions so parts are not as easy to come by later. Outbacks are a good bet for your size family.
Here is the answer, the POS PO took out several bulbs from the dash, ABS, check engine etc and sold it to an unsuspecting young girl who experienced all sorts of issues and sold it to me for damn near nothing. So the light was on due to a couple of minor issues that were easy to fix, but he ripped her off. I feel bad for her. When I put the bulbs back in, replaced the knock sensor the MIL on turned off. All is good now. Just for future reference, after resetting the check engine light, it should tun off the MIL via the reader as well.
the p0136 was an o2 sensor bank 1 sensor 2. neither has come back and I am up to about 50 miles now but still need to weld up the exhaust leak from the trans swap. It looks like 4 screws to replace a bulb behind the dashboard. Is that right? I saw a YouTube of a guy who removed the steering wheel to get at the dash. Is that necessary?
Thanks everybody for the replies. Codes were clear, but mil was on before new trans. I could tell the MIL was on via my OBII reader only. Drove it very little cuz trans was eating itself up as I drove. Got to the shop though. Put in new trans, 16 at flashes.....great. Swapped the duty c and clutch pack from orig trans and now it drives good and runs good. Drove it 20 miles today, but it has an exhaust leak from the trans work. Exhaust will get fixed tomorrow as well as some new front rotors & pads. After the exhaust repair, I will test it again and see it if the MIL on clears or is able to turn off. The bulb does not illuminate at start. Is it hard to replace the CEL bulb or put one in after the previous owner possibly took it out? PW
I am stumped. I had a P0325 and a P0136 upon first read. Cleared the codes and still have a mil on based on my reader, but no codes. The check engine light on the dash is not illuminated. It might be a burned out or removed bulb by the previous owner. Anyone have any ideas? The engine is a 2.2 auto trans. Just replaced the trans. Car has about 135K on it. I tried to turn off the mil via a reader, didn't even restart the car and the mil is still on. Bad ground maybe?
I just got my email as well last Friday. Cool program. The should add some stickers to the swag area.
I have had a 02 LL Bean for 6 years. Nice ride. I would bring some coolant and go back & drive it again.Before starting it, check the radiator and the overflow tank to make sure there is sufficient coolant in each. See if it starts right up this time. Almost sounds like it needs a thermostat otherwise. Make sure you get no bubbles in teh overflow coolant tank after it is good and warm. Ditto on the rest of the comments. I would offer $2400.00 if it all checks out.
