26
Everything posted by jonathan909
I think that's the date range. I have an '01 Forester, so I'll be messing with it there as well. And I have a bucket of fobs from the junkyard to play with. Well, sort of. Unfortunately, the first part of the plan is to go on a raging tear through the house - when I first started looking at this for the '02 Forester, I printed some schematics out of the service manual and made a whole bunch of notes on them, and now I can't find them. Since I don't want to recreate those notes from scratch I'm going to be a real pain to be around until they're found.
Not sure what's meant by "confusion as to system". I'm certainly not confused about what I have here - it's all Alpine hardware, and the instructions are consistent with those published for later model years. I can't comment on what came before, as (afaIk) the keyless entry wasn't supported in my earlier ('95 and '98) Legacys. Unless someone offers some really revelatory new information, I think my next step is building a test jig for these things so I can, at least, control the I/O rather than just trusting the car to provide sane and predictable inputs to the module.
None of the above, I'm certain, for the following reasons: The battery was disconnected for at least a year while the car waited for me overhaul the engine (the product of both winter and an ungulate conspiracy, as I've previously noted). According to the owner's manual the security system was an option, and I don't think it's in here because there's no indicator light on the dash (to the left of the fog light switch) to show that it's armed (or that valet mode is active). Incidentally, I fought with the stuck-in-valet-mode problem with my late '02 Forester: I think that Alpine designed a trap into it, in that you use the key fob to enter and exit valet mode, so if it's entered, then you lose the key fob, you're stuck in valet mode with no way to exit it, and I'm pretty sure that valet mode inhibits programming a new key fob - so you're totally SOL stuck. I've dug around a lot and even called Alpine about it, and there's no detailed information out there that might, for example, explain how to exert a hard reset on the module. I've even started trying to figure it out by pulling the EEPROM off of the keyless entry module so I can read it out and see whether anything can be learned by comparing a bunch of them - but I can't make any progress on that without a running system to reference. Someone out there must actually know something about these problems. Flailing around at it is a waste of time.
It's never worked, and I've decided to make it. When I do the cycle-key-10-times thing it does not beep the horn to indicate entry into programming mode. If I use the driver's door switch to lock the doors, it does honk the horn when I close the door. The fuse that's supposed to supply it (according to the owner's manual) is good. I've tried a couple of other modules fetched from the junkyard (though their part numbers vary slightly from the one that came with the car), but none have brought a change of behaviour. Can anyone suggest any leads, any known gotchas that would inhibit its entering programming mode? I'm hoping someone can just pass me the secret answer, although I'm pissed enough to start reverse-engineering this thing
This is probably suitable for a fresh thread, but what is the best/most cost-effective tool for getting live data? A few years ago I got FreeSSM for windoze (which didn't look like it was being actively maintained) and went through the whole thing finding a USB-OBDII cable that it'd work with. I don't carry a tracking device, so the "smartphone"/bluetooth dongle combo doesn't really work for me. Are these the only choices, or is there something better our there?
Situation's rather more complicated than that. STBPOIH (Soon to be previous owner, I hope), who is a FOAF, left it there after a failed DIY oil change that resulted in a blown motor. It's been sitting for 14 months because he was severely dispirited by this (and other life events). Why the shop has allowed this is unknown to me. We're talking about my taking it off his hands for scrap price (or not too much more, I also hope), hence the need for the haul. A few possibilities have surfaced since my original post, including some local (to me) guys who may be flatbedding another car up into the neighborhood of where this one is and were otherwise going to deadhead the return. And if that doesn't fly, I just heard from another friend that U-Haul indeed does carry flatbeds up here - total news to me. So it'll get sorted out... So to return to the original suggestion: With some effort I might be able to convince CAA to do it, but I'd be conning them. Sometimes I'm okay with that, but not so much this time.
Any time a fault responds to a wiggle, you really have to dig in and look closely. Last time I had problems that responded to wiggling stuff in the under-hood fuse box ('02 Forester with intermittent ABS fault), the trouble was corrosion in the box's connectors. Pull out the fusible link and look down into the pins it mates with. Any green residue suggesting copper decay?
Yeah, it just strikes me that if there were a problem with the clutch work, it would have shown up a lot sooner than 30K miles. I'm always extremely suspicious of "coincidental" failures - if you have two problems at the same time they're probably related. But that's an awful lot of time and distance for the two to be related problems; more likely "unfortunately neighboring".
I need to move this car 70km, and the flatbed quotes I'm getting are too high, given the circumstances, so I'm considering DIY. First, the information out there (apparently from Subaru) is that flat towing is okay for a car with a manual transmission. Does anyone have facts that contradict this? Second, how to attach my A-frame tow bar? The adapters I have attach via a single bolt (on each side) to/through the bumper/frame - fine for towing old Detroit iron like my Ramblers and Dakota with big steel bolted-on bumpers. But how about the WRX? Taking the bumper off to get at the frame seems like a terrible idea - the parts guy at the local dealer told me that the clips that hold it on are worth more than the bumper itself. So has anyone fabbed an adapter that bolts to the front tiedowns, then reaches down and forward to clear the bumper and connect to the tow bar? Or does someone manufacture towing adapters like this? Am I even thinking in the right direction? Btw, if we go the DIY route, we do have a 2005 Legacy GT handy that we can use as a model. Is that close enough to the 2010 WRX?
A little story, if I may. When I bought our first Subaru seven or so years ago, I knew it was overheating and that I'd be jumping into a head gasket job right away. So I started asking questions (on another forum) and found a lot of help, including the same admonition to stick with the OEM thermostat. I asked why, and to the forum's credit I got useful technical answers about its hysteresis characteristics and aperture size - stuff engineer-type geeks like. So I headed on down to the dealer and told the parts jockey that I needed a thermostat. He said "Be right back" and immediately turned to fetch it. I tried to stop him - after all, I hadn't told him which model, year, engine, or temperature I wanted. He replied "We only have one." That was the moment I decided I liked Subarus - a lot.
