Everything posted by sirtokesalot
engine ticking when cold
ive been noticing a tick when the engine is cold that goes away within a minute or 2 of driving i have provided a video of the sound u can hear it more near the end when i stop and open the door at the end of my driveway. this is on a 2001 outback 2.5 engine. what do you guys think this could be? ive been thinking maby a valve tick?
steering woble
it does seem to be less of a wobble while its turning vs just rolling strait.
steering woble
yes i took the calipers and rotors off cleaned the hub surface the back of the rotor mating surface the front part of the rotors mating surface and the back of the wheels surface so all points of contact were wire wheeled clean.
steering woble
it rocks left and right slowly and the faster it rolls the faster it rocks back and forth. id say maby about a half an inch of left right movement
transmission compatibility?
and to update on this situation i decided to jack the front end up from the cross member under the engine and try to drive the car. it will push forward on just the rear wheels alone so i do think the awd is working and i did not change the rear solenoid valve. im not going to unless someone can give me a good reason too.
steering woble
update i took the front brakes apart today both front calipers the pistons are free and can push one in by hand the other comes out and will do that with ither piston i push on the caliper. slide pins are free and lubricated pads wearing evenly i decided while it was apart to wire wheel the corrosion off the hubs and the backs of the wheels re inspected everything tie rods still good lower ball joints still good bearings good put back tires/wheels on the front and the wobble remains. what els can cause it? the car drives smooth other than the wobble and has no bad noises from the wheels or suspension this was not suposed to be a quote i dunno why it quoted that messege. no axle noises no torn axle boots
steering woble
ive been noticing a steering wobble in my 2001 outback it was there both before and after changing the front hubs i also tried a different set of tires and wheels the wobble remains. what can cause the wheel to wobble when driving? at slow speeds its a slow wobble and as u go faster the wheel wobbles faster. it has good lower ball joints and tie rods nothing seems loose in the suspension im just not sure what to look at from here.
so do i have to actually swap the valve or could i just swap the whole rear half of the case with the valve in it? im still not really sure if i need to but im guessing i should anyways while i have the transmission. ive been noticing some front wheel spin sometimes and been questioning if awd is working pr not. i think it is kind of because it wont keep spinning for long on wet grass but will spin sometimes on wet pavement and in gravel very easy. yet there is also a very noticeable difference between fwd fuse in and fwd fuse out so maby its just that im not used to the extra power and taller gears? i came from driving a 2.2 outback on 3.90 gear set to the 2.5 outback on 4.44.
still have the old transmission dont want to dump it till i have an answer anyone know?
so considering the transmission seems to be working as it should does that mean i do not need to change the bit in the tail? i still have the old transmission but im not going to keep it around if i dont need to pull those parts.
im not sure i havent tried. i can say after i drove it for a bit i felt like it spun the front tires a few times it was raining but when i was at a friends house he let me pull it into his yard on the wet grass in a hill and i floored it and the car did not spin on the lawn it just bit down and went. *edit* i just went out into the gravel driveway without fwd fuse front spins for a second then bites and goes with fwd fuse in the fwd light comes on and it tears the driveway up roasting the front tires only. i do think the awd is working.
It came from a car with a build date of 01/2003 does this need to be done so it hard to do and can it be done with it in the car? I can say that I drove it and it seemed fine. There's no warning lights on.
can anyone confirm if the transmission tz1a4zceba-3k is in fact a 4.44? i would really hate to put it together tomorrow with the 4.44 rear diff then blow it up from a wrong ratio issue.
How's this for a rust problem?
sirtokesalot replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol my friend has one like that the wheels even started pulling outward when we moved it in his driveway how about this one thogh
i passed on the 100 dollar one that was outside. the one i was asking about was the one i just bought so i hope it works. it has only been off the car for a few weeks and was kept in a garage i bought it from a subaru tech and it came from a 2004 outback 2.5 according to the info its a 4.44 transmission and should work just like the original im hoping. has 146,000 on it. ill know wensday if i made the right choice when i put the new transmission in
Ok just want to be sure I found a 2004 outback trans now for 150 the 2004 trans will work right? I dont k ow the ratio on this one thogh I'm guessing 4.44 I can look ot up later. I have both 4.11 and 4.44rear diffs The transmission I found is tz1a4zceba-3k I'm not sure the original but it will be going into a 2001 outback hope to hear from someone before this afternoon want to pick this up tonite
heres the 2 pictures. the guy said its been there for a couple years and it was covered but not sure with what.
is there any reason to fear a transmission that was stored outside with the axle stubs in and tail sealed? i found a 100 dollar 123,000 mile 4.11 legacy transmission.
front hubs?
will the front hubs from a 2001 forester work on a 2001 outback? i know the forster was using the older 95-99 outback style suspention and i know the rears are different but what about the fronts? if i can use te parts i have i wont buy more.
wiring question
i have a 2001 outback it was a base model and has none of the plugs for stuff like heated seats heated mirrors rear/front tweeters. i know these plugs are located on the main body harness tail gate harness and both front door harnesses. my question here is if i were to swap these harnesses into my car from a doner 2002 outback limited would those options then work or is the dash wiring where it plugs in also different?
ive been looking i jsut dont have cash for one currently. exploring my options. i was almost going to trade the 1998 impreza for a low mile trans but then realized it was a 2006 transmission and wouldent have worked. yes i would trade a running car for a transmission exp when said car was a free car. i do know i could get more by selling it and buying a transmission but it needs more work before i would sell it.
im going to assume i cannot use the transmission from a 1998 impreza can i? i have one of those on hand in another car i got free.
Rear hatch won't unlock, locks fine. Motor works
re attach the wires. the other end is likely there somewhere.
what number bulb is it?
does anyone know what the bulb number is for the ashtray and shifter lights? i know there both the same they look like a 194 wedge bulb but much much smaller. there both burnt out in my 2001 outback.
