84 Brat shifter neutral resting spot
Has anyone tried pressingonward's linkage improvement? Is it worth it?
Parting out 1986 BRAT GL
Do you still have the handle+cable for the hood release?
Ever Seen A Nardi Steering Wheel Adapter?
If the Nardi is too much, you could always give this a try: http://www.ebay.com.au/itm/331183683007?ul_noapp=true
2002 Impreza RS low compression issues
Muffinland replied to Muffinland's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had this car since July 2015. It's always been rich and it's always done subtle backfires, but never like it is now. The problem developed about a month ago.
Muffinland replied to Muffinland's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is originally what I thought was happening, but all of the timing marks were where they should be. All the teeth on the belt are also in fine condition. Is there another way that the valves could've been damaged?
Muffinland replied to Muffinland's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou believe it's the actual cylinder head itself?
I have a few questions regarding my 2002 Impreza 2.5RS. It's having some starting issues. Sometimes it will start immediately, some times it will hesitate on starting, and other times it will just crank without actually starting. Every time it does not start, it sounds like a rifle has been shot. Here's whats been done recently: I've changed wires, both cylinder head cover gaskets (including the 4 spark plug boot gaskets), the timing has been checked (no belt/pump needed), and I've changed the crankshaft sensor. Earlier the car started like normal, but when shut off and I tried to start it again, it misfired and didn't start. Today, I went to the shop that the car is sitting in now, and we checked the compression for the pistons. Here's what we got: Cylinder 1: 60 PSI Cylinder 2: 135 PSI Cylinder 3: 30 PSI Cylinder 4: 120 PSI My mechanic seems to think that it is the camshaft, and that makes sense, since it is just the 2 passenger cylinders. However, he is not sure, and I want this done as quickly as possible. So my main questions are: Has anyone experienced this before? Are there any ideas that someone has? Is any other information needed? Thank you for taking your time reading this and for any feedback.
Bipolar EA81
The cat was not replaced, only the piping, resonator, and muffler behind it.
Bipolar EA81
Symptoms include when I lift off, it rattles a little bit and will give off little pops (sound like really quiet backfires). Symptoms for when I'm attempting full throttle at operating temp in 4th gear are a missing sound. It doesn't even sound like its igniting. It will give the normal sound of a WOT and combustion and then all of the noise stops and it takes me down until I lift off the throttle. Cap and rotor look very new, points are barely worn. The spark plugs look as new as the cap, rotor, and wires. I do know that some spark plugs can come bad, or if they're dropped then they are as good as done. Today I also learned that the car probably had either a bad fuel pressure regulator or it was converted from mechanical to electric. There is a very shiny bit that is zip tied to some tubes in the engine. As for fuel I was told to try 89 octane and I'm sure that that is what the GL is running on now. Looked it up and the article said that after long amounts of years without rebuilds, engines get carbon buildup and may need higher octane. How do I know if I have hydro lifters or solid? I'll have the compression test done by Monday, hopefully. Thanks very much for all of the suggestions. This helps a ton.
Bipolar EA81
Sorry, I just never heard of a car with 2 fuel filters. Everything I've worked on has had one. How common is the dual filter setup?
Bipolar EA81
My instructor for my school said that the fuel filter was in the top right of the engine bay. It's also see-thru and looks fairly new. I may still give it a try. Thanks for the answer.
Bipolar EA81
Sorry if this sounds silly, but are Hitachi's hard to clean? I've only ever messed with lawnmowers. I'll also need new gaskets, correct? Thanks for reply
Bipolar EA81
Unfortinetly Im not the original owner. so far I've gotten a new exhaust from cat converter to the muffler and thats all regarding the engine. I have slightly touched the carbs fuel mixture, but I only went about half a turn, and that improved my performance, it didnt hinder it. Thanks for the answer.
Bipolar EA81
Hey I've been having a few issues with my performance on the highway since I bought my 83 GL Wagon 4WD. The issue is that the engine is very unhappy in 3rd and 4th gear. I was totally convinced that it was the winter weather of Michigan holding the engine back at higher speeds, but today we hit 70 degrees F and the engine still drove rough. The engine will almost always go up to redline in 1st and 2nd gear while I'm hopping on the highway, but once I hit 60 mph today, the engine refused to go over. However, it was only a few days ago where after work it was about 50 degrees and on my way south, the speed was incredible compared to today. It hit the end of the speedometer. Yes, this is a teeny bit over the limit, but I'm just trying to find an average here. The crazy thing is, is that on my way back north the engine was struggling in the 60-65 range. Why is my engine so inconsistent? Is this just the nature of the beast? Or is there a junk part somewhere? Thanks for reading and any answers I receive. If I'm not specific enough, just ask and I'll try to give more details.
Stud size and pitch for 83 GL 4WD
Hello, I was wondering if anyone knew the specs for a wheel stud. Recently finishing a brake job, I was trying to put the wheel back on, but found that one stud has its first four or five threads flattened. I was hoping that it isn't anything out of the ordinary and its a die I would have around the house.
