Gasket97
Everything posted by Gasket97
Help me before It drive it off a cliff
Gasket97 replied to Gasket97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Swapped in a junkyard dizzy instead of replacing the crank positioning sensor and it runs great again, thank you for all the help -
Went and pulled a dizzy from the junkyard and it's runs!
I think I've got it narrowed it down to the crank position sensor
Its grounded, I may try picking up a junkyard unit for it
No I have not been able to yet -
What is the little black box attached to the coil bracket?
What is the little black box attached to the coil bracket? -
I tried the wire and I get a yellow spark, I will check the coil with the key on
I have an 1988 gl wagon I have no spark, I checked the coil with a multimeter and when I cranking I'm only getting about 5 volts to the coil, the coil is only a couple months old, the fusible links have continuity, my timing belt is intact and spinning, my rotor screw is in and the rotor is spinning, the cap and rotor are clean as well. Where should I go next?
I believe the square one is the fuel relay and the round one is the ignition, that's how it is on my 88 gl, I don't know if there is a difference
Thank you scott -
Out of curiosity does the ea82 NA spfi have an ignition control module and could that be the issue? -
Not that I know of -
Not that I know -
Tried replacing the relay today, tried five different used ones and the problem remains the exact same, I checked the fusible links and they seemed to be in one piece -
Thank You superpoo for the idea but no luck -
I found a relay under the dash that was making the clicking,I looked the number up that is on it and i5 came up with a direct ignition relay, the number printed on it is 056700-5260, I tried to get a replacement at napa and oriellys and rockauto but they all have the wrong plug layout and diagram, Tuesday I am going to the junkyard where I know there are a couple loyale/gl's and I will pull and try those -
Fixing my ea82 need some advice
Gasket97 replied to Bluegoblin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Then I would say it's for your ac pump
