Everything posted by Torry33
Building a lifted GL
Got more done today!Radiator is in with hoses fit.got the EA hose to fit the top outlet and had an old hose laying around that fit the bottom.power steering pump is hooked up and the intake with all the breathers are in place,just need a cold air filter to fit in there nice.redid the fuel filter to the EJ style in the engine bay,with high pressure lines.old fuel pump is hanging by the wires,ready to get swapped for the high pressure one.been dodging rain drops all day here!sucks doing this in the driveway but Idont have garage.getting it together!soon as i get this EJ dialed in I will start getting things together for the lift.already have some 235/75/15 on 6 hlole mazda wheels.would like to get some pics up as soon as i can figure out how to post them.cooling fans and start the harness tomarrow!
I've been wanting to build another lifted wagon after giving my daughter my 93 lifted Loyale.So I found a super clean 86 GL wagon and picked it up for my project.155,000 miles on a rust free car with incredible interior for the age.This is the KEEPER!so plans include a 4 inch lift and an EJ SWAP!!and it happend today!did a power steering transplant from a 91 Legacy to my GL,that didn't have power steering.a couple of mods to that and it fit it there!Next I got ready to drop the EJ in.Slapped on my ADF adapter plate and clutch pack.cut the nipples off the EJ mounts and lowered the motor.after a few adjustments and BAM!its all bolted up in the engine bay.hopefully I can get it fired up tomarrow!have a thinned out harness that looks in order.that process took three days!installing the high pressure fuel pump out of a Loyale and running new fuel lines.Have a brand new radiator and some 12 inch cooling fans.Making progress!
IGNITION KEY LOST!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks everyone!ended up going to the Subaru dealer in Whitefish Montana.had two keys cut at the cost of thirty dollars.worth the drive!plus we had a dentist appointment for the kid there anyway.
IGNITION KEY LOST!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalrighty! thanks guys,the closest dealer is 90 miles away but ya.
IGNITION KEY LOST!
OK so my girlfriend lost the only key to her 97 Legacy.i have a 91 Legacy that is my donor car with a keyed ignition.will those inter change?they look the same and the key from the 91 fits in the 97.already have the 91 down to just the column.is it easier to change the whole column or just the key part
6 Lug Steel
those say thats a 16 inch.might be tight to fit but depending on tire size and lift they could work.
Picked up an 87 gl wagon
there is a mixture screw right in the front of the carb.try turning it in until it starts to sputter and then back it out till it runs smooth.also there is an accelerater pump adjustment on the back of the linkage.maybe your not getting enough throw to give it a shot of gas when you accelerate.check for hoses that are possable air or vaccume leaks
Adding Power Steering
i have a 86 GL 4X4 Wagon and it doesnt have power steering.im EJ swapping it and would like to have power steering since i will be lifting it and running larger tires.i have a Legacy parts car with power steering.will that rack work in a GL?also i noticed there is no hole in the GL crossmember for the lines to pass through so im assuming i need to change the crossmember to a power rack one.
6 Lug Steel
just scored some 235/75/15 on chrome Mazda B2200 six hole rims for 100 bucks off a truck in the field behind my house.got to love it when you find stuff like that!perfect off set for the subbie after i get the lift done so i can fit them.
6 Lug Steel
hey there Whitefish!im over here in Libby.getting ready to do my ej swap!i would check some local wrecking yards and see what you come up with.the last set i did were some aluminum wheels of a nissan and they fit nice and didnt stick out to much.i do like a little offset,but maybe you can judge it better while its still on a vehicle.
TACH WIRE CONFUSSION
ok i figured it out!i had it right,just didnt reilze it was a switched ground.Goyale had named the same pin i was using.#16 atB56 on the ECM.
well got the harness thinned for my ej swap.everything seems to be in place but the tach wire.it leads to a ground.on the back of the cluster off the 91 legacy there are three connections for the tach.i used the one marked TA.the other two are marked GRD and IGN.after tracing the wire down it led to a ground.what the heck!any help?
EJ SWAP HARNESS THIN QUESTION
ok thanks.
ok doing the harness thinning process on my swap.my question is the harness from my donor car is an automatic.there are two computer boxes and the one with the EE on it i'm assuming is the control box for the auto trans,but some of the wires are linked to the plugs on the engine control box.can i cut those wires?the write up im using doesnt show any of that.
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi will do a compression check to see where thats at.when i put the timing belt on all the marks lined up and i checked it several times by rotating the crankshaft.it has new spark plugs and wires.it does pull nice when accelerating but i do notice a little miss i can hear at the tail pipe
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell i did it!just put the engine back together and its running great.did have one little issue with a stuck thermostat and a loose hose.blew the antifreeze,but got that fixed and put another 150 miles on it with no problems!it does have a CEL on but i think it was on when i bought it.engine shakes a little at idle but other wise runs strong.brand new plugs gapped at 44,new wires.happy with it so far.lets see how long she goes!
- CANT UPLOAD PHOTOS!
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim kinda at the point of no return on this repair.already have new head gaskets and other engine gaskets.new timing covers to replace melted ones and having heads shaved.how hard is it to change rod bearings?ive built several air cooled vw engines.that are simular design.its down to the short block still in the car right now.
CANT UPLOAD PHOTOS!
cant seem to get any pics to upload on here.says files to big.using a Canon power shot 16 meg pixel camera.
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK....did the oil filter inspection and there was some brass colored particals in there.mostly real fine but there were a few bigger pieces.i wounldnt say there was alot but a noiticable amount.i do have a 91 2.2 ej i just got for my swap but i could use it if i have to.so will a 91 ej 2.2 go into a 97 that has ej 2.2
Walker Valley off road video
they are on Youtube under Subaru offroad i think.north west subaru club in the seatle area.
awesome footage of subbies gettin dirty!my question is the last car in the group is a maroon wagon.any info on that car?like lift height and tire size?that thing is a beast!i have the same color wagon and that rig is my insperation for an awesome build!any info would be great and thankyou!
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi will get some.heads should be done today.thanks for all the help.im a good mechanic but fairly new at some of the prosidures on these subarus.pretty excited to get my ej swap started on my gl.got three subbies in the driveway!
Teardrop Trailer
Torry33 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbeen planing on building one to town behind my lifted and ej swaped 86 gl wagon
CYLINDER SCORING!
Torry33 replied to Torry33's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoes the lube have to be amsoil.i have some white engine assembly lube.i will get some if thats what works best
