cookie
Everything posted by cookie
equipment I agree. Jimmy diesels have used steel O rings for years with little rubber o rings for oil and water passages. They can take a beating for half a million miles. When I was a kid I had a Norton I fitted with a soft thick copper head gasket. Stopped all gasket problems I was having becuse of an extreme compression ratio. Sealing head gasket surfaces is nothing new and I am surprised Subaru has done such a bad job of it. The thin metal gasket of the new ones is a bit better as they are allowing the head to support the liners. Studs would be good except for the head removal problem.
in good condition and the ride is fine. Tires, springs, and stuts have to be viewed as a system. In order to get a working system you can't change bits willy nilly. If the ride is too harsh go to tires with a bit more profile. The cheapest way would be to try a friends similar tires on yours to see if that is what you want before spending a lot of money. If you are trying to make a performance car you will have to live with less ride quality. My BMW rides like a truck but it is flat as a brick in a corner.
possible that the low oil pressure may have triggered this by the famous weird knock sensor. It seems to me I have heard of this being an oddball Subaru problem. I suppose it is also possible that the low oil pressure triggered it. I would have it checked ASAP by a competant Subaru mechanic as this might end up in court. Good chance it will be minor, it is also possible they knocked off a sensor wire.
shops in that area are too lame to be able to test your heads plunk them in a box and send them to CCRNC to be checked and rebuilt. If they they say they are good you should be fine. Is UPS too lame to send them?? I am amazed because I could test them in my garage and I don't have a whole machine shop.
2.5. It does seem that you can cure the late 2.5 and even if you do get a leak an external weep is not that scarey. With the new gaskets I have no problem with mine and gosh subaru is going to give me a whole can of goop free! Plus the 100,000 mile head gasket warranty would make me feel better on a post 2000 Legacy or 99 up Forester.
pretty quick. I just got about 27,000 mile on a set of Dunlops on my BMW. I have Bridgestone S03s on there now for about $1,000 mounted. Will probably get less mileage out of them as they are softer. Check Tirerack.com for all the evaluations and ask over there on the tire expert board. The Michellins on my Subaru are the second set at 100,000 miles and sure are holding up well. Since I bought it used I don't know when they were changed. I think that unless you have a pretty serious suspension under the car or unlimited money a compromise tire would sut the car better. Tire Rack has reviews and if a lot of folks liked them it is a good sign.
