cookie
Everything posted by cookie
I was considering another set of michies, probably the Hydoedge. I decided to go off brand and try Big O since I have a friend who owns a Big O shop. The Big O Aspens I selected were fairly cheap at $68 a tire and look sort of like a Michellin copy. They are quieter than the old Michies were and so far do everything as well. Another 65,000 miles will tell if they are still hanging in there like the Michellins did.
Run by the door inflation. The marking on the tire is only max as required by law. The door inflation has been adjusted for car weight and characteristics during a controlled test period and odds are its a lot closer than you will work out yourself. The struts that came off my Forester from the factory said KYB on them and the GR2s are just a bit stiffer, I've heard 15% and can beleive it.
actually oil does help piston slap. I have been experimenting for a while with oils and have seen quite a difference. I have used Pennsoil 10-30, Mobil 1 10-30, Mobil 1, 15-50, and now Havoline 5-30. oil tests are good with all of the above and the Havoline is the quietest, next is the 15-50 Mobil 1. I have no idea why the Havoline was quieter and it was not my idea, some of the guys on Bobistheoilguy reported good results with it. I like extended OCIs myself, but for the quiet I'll change more often with the Havoline. Next time I might try the Delvac for chuckles. It was always good in my diesels.
Results may vary. While this may sound too good to be true there might be a few factors that are giving you a bit better than normal readings. Perhaps the gas pump shut off a bit early or conditions were absolutely perfect. Could have had a great tailwind. Try it over a period of time and see what happens.
You too frag. By the way it is common on some engines that when they wear more air gets by the throttle body. most throttles leak a little, but not so much the IAC can't compensate. Sometimes they have bushings that wear out and make the mixture hard to control. Not sure about your model, I'm sure somebody here will tell us if that's an issue. I sure have heard of lots of folks sying thier Subie had carboned up (much more than other modern cars I know of) and I reckon it can't hurt to decarbonize. I have also heard of lots of folks having idle problems from cracked lines or IACs that need cleaning. The only problem I've had lately with the Forester is noise in the rear I thought might be a tire but maybe a bearing. I had it put on a lift and it is a tiny tire seperation so I got lucky. Good luck on your trip mate!
