cookie
Everything posted by cookie
As for moving to Alaska Nip, as far as I'd go would be Tahoe... I think 50-50 also gives me the lube and anticorrosives I want in there but that reminds me I should check out those hoses before winter. Sure is a lot easier to change them in the current warm weather here. The fact that if you add too much antifreeze you actually lose freezing point is why we alsys used a hydrometer. At five bucks or so they are much cheaper than frozen engine blocks.
We have had a few reports of high mileage 2.2s having piston slap. Remember Setright? I would not sweat piston slap but sticky lifters would bug me. Are you near anybody who could listen to it for you? They are quite distinctive sounds and lifter noise often stays when warm. I just switched to Havoline in mine and it made a big sound change in the piston slap, much deeper, seems to muffle it a bit. I got the idea from folks on bobistheoilguy. I was kind of skeptical since I used to run Pennsoil dino and I figured Havoline to be about the same but it isn't.
It might just mean things are a bit old. If you have reduced the tick to only when cold perhaps the other half of the MMO on your next oil chance will cean it out furthur. You might check on bobistheoilguy site becues those folks do a lot of cleaning on older engines and you might get a tip you can try. I'm of the tear it out of there and put a new one in school so I'm not the best guy for this kind of thing. When my Mercedes had a tick at about 200,000 miles I rebuilt the engine and after teardown I could have gotten by with a valve job and new cam and lifters. I did have peace of mind though....
Get at least a 99. The 98s had the same phase 1 engine he has now with a bit more chance of head gasket failure and much harder to work on. The phase 2 that starts at 99 in Forester and 2000 up in Legacies is a simpler single cam which is an improvement. Oddly enough I have a 99 Forester for this reason. You can still have a head gasket leak but it tends to be an external one that can be cured by a sealer, or the early ones have an extended warranty on the head gaskets until about 100,000 miles if I recall correctly. They still need to have the oil level ket up though.
Most of them slap when cold. If it does not go away when warm it may be a problem. Oil burning is relative. On that car if you add a quart to 1500 it may be on the high side of normal for an old car. Of course some will burn little oil but if he is running it low he will soon be damaging your checkbook.
For me I read the directions on the jug and the car manufacturer's reccomendations. I don't trust the Porshe club as far as I can throw a 911. I prefer to get my advice from engineers and chemists rater than lawyers and dentists in this area. Now there are other areas I prefer to get the advice from the lawyers and dentists...
On my car PO420 was just a slow front sensor. It took me awhile to make up my mind what to try so I cleared it a couple times and it would go away for months. Did not seem to make any driveability or fuel issue on my car, just that glaring light. I would not have gotten through and emissions test here with it. Keep in mind mine was a small issue compared to a plugged or broken cat.
