cookie
Everything posted by cookie
Noisy interior
cookie replied to Leg93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My Michies on the Forester definately don't help the noise. On certain smooth pavement they are quiet bu the tread is a tiny bit aggressive. Tires can make a huge difference. -
I'd like to say I've never left a wire or the big hose under the air cleaner off, but... This seems to take the place of timeing the engine to the wrong cylinder like we used to do to frustrate ourselve with an engine swap. After you work on it for twelve hours and are in the dark except for a drop light you can make a lot of errors that clear right up with daylight and a good night's sleep.
Noisy interior
He probaly can't hear over the sound of his praying. -
Adjust TCU?
cookie replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That was probably the last thing they changed and it finally worked. It does make sense but you never know if it was the problem in the first place. When they swapped trannies they may have needed the TCU that came with the tranny to get it to work right. Your car was probably a fiasco for those guys. I'd like to say I have not been there but I have. After you finally get it to work you usually find you expended five times the effort you needed to. I once changed a bus muffler in Oakland and the bus overheated on the Bay Brigde to SF. I figured it had to be a deffective muffler and put the old one back on. It still overheated and I started pulling everything else apart from the thermostat, 300 lb radiator, the 100lb shutters, etc. I finally found the water pump drive had just happened to shear off on the trip back. Then I got to put it all back together including switch the muffler again. If the muffler had not weighed 200 lbs and been behind the engine in a Greyhound bus it might have been easy. When a job goes to%#@& it really goes to *^#@! -
Adjust TCU?
It sounds like they were having a bad time with your car. Most of the times jobs go well but when they go down the tubes they seem to snowball. It sounds like they chased the problem on your car and just kept changing parts until they got it to work. -
Adjust TCU?
Often when a tranny is rebuilt the shift point can change. This is becuse the clutches are now at maximum thickness and although the shift is triggered at the same time the engagement point changes. -
Oil sure can make a difference in a tranny as well as an engine. I was whineing about my tranny being the next thing out on my Subaru about 40,000 miles ago and had the tranny oil changed. It cut noise about 50% when going for original fill with about 90,000 miles on it to new oil. this was nothing spechial, just dealer stock. Setright was one of the folks who told me the 5 speed might whine on forever and right now it looks like it might. All modern oils are very good but some are just a bit better than others for particular purposes. I've noticed improved shifting on my BMW when changing from Redline to Specialty Lubes MTF Glide. Recently trying Havoline in my Forester seems to have cut piston slap. Oil is somewhat cheap to experiment with.
