Everything posted by cookie
Clutch Pedal Not Returning
cookie replied to Hydroman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI read the TSB and replaced the Subaru reccomended parts for the same problem. It was not right yet as I did not have enough pressure from the master. After replacing the master too it has been a couple of years with no furthur problems.
Help! 1999 Outback Phase ll Block, DOHC Heads
cookie replied to steve2005's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sorry, I meant internal. I have brain damage today. The conditioner is unlikely to do much for your engine.
Slow & Wussy Power Windows... How to make them better?
cookie replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen just try some silicone spray.
cookie replied to steve2005's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you ever leak it will be external. Replacement of the gasket should be a permanent fix. Sorry, you have the poor gasket design. Put a few bucks by for replacement if needed, and if you never need it throw a good party.
cookie replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLike Nipper said before, you don't want to gain too much speed. If you are serious the first thing I would do is pop the panel and remove the contoller fomr the window. See how much pressure it takes to go up and down. Clean and lube until it is easy.
EJ25 and a WRX 6-speed tranny?
cookie replied to thesubarukid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't the WRX have a pull clutch too? Somebody has probably done this already but I would expect it to be difficult and expensive.
cookie replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpray some silicone lube down the track and see if you don't have a miracle. If you add more wire you will just overheat something else when the real reason is resistance to movement. Lubeing your window tracks in the door should be done with white lithium whenever you have the panel off. Also lube your losk and such. Treat all rubber on the car with a rubber treatment too and it will help the car stay water tight.
SOHC or DOHC???
cookie replied to zbrink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot on Foresters. They got the SOHC in 99. The Legacy Outback got it in 2000 in the US. The only reason I have a 99 Forester was to avoid the DOHC in the 98s.
SOHC or DOHC???
cookie replied to zbrink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a 99 and in America it's SOHC.
Catalytic Converter Replacement
cookie replied to wandersub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a PO 420 and was assured that it was my converters. One front oxegen sensor later for $60 and it has been cured for a long time. I vote with Nipper to try that first. If your car is a CA model it will have a sticker saying so.
Suspension upgrades
cookie replied to scorch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was advised here to try the KYB Gr2s on my Forester. With those and an Ebay WRX rear swaybar I ended up with a pleasant handling car that is neutral front and rear. And I also use an air wrench on struts, it beats heck out of any other method I've seen.
Swapped Engine is Rocking/Shaking
cookie replied to CIS Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGas turns to varnish if left untreated. If possible before storing an engine one should run it out of fuel. On my Pontiacs I don't drive I use fuel treatment because of apst hassles.
2001 Forester Opinions?
cookie replied to librarygal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat transmission does it have? I have a 99 Forester with 5 mt that is doing fine at about the same mileage. If the car has had all the proper service it should be fine. Have it looked at by a subie expert who is on your side.
Pulling EJ25
cookie replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome of them stick by the pins. You also have to pull the brace I understand. Some folks have had a real struggle helped by levers and penetrating oil.
hope someone can anwser this question.?
cookie replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn some vehicles the seal retainers set the play on the ring and pinion. This is not really by inch lbs but by gear pattern. On this type if you carefully mark where it is currently and the exact number of turns to get there if the spin type you are fine. With the shim type you just put the same shims back in that were there in the first place.
23 MPG alright?
cookie replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGee, you would think Meth heads would have energy enough to do more of the maintenence.
check engine light/cruize control light flashing
cookie replied to walkman05's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's interesting. With a loose gas cap the light will flash? I have just seen them come on steady, but the only time my Subie did this was when it wanted an ox sensor. My BMW wanted a new $1.00 gasket on the gas cap and the light was also steady. You learn something every day.
23 MPG alright?
cookie replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 Forester wagon, I average a bout 25 or a bit less city and freeway.
cookie replied to walkman05's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure you checked all the fluids and checked the manual first right?
cookie replied to walkman05's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAutomatic or manual trans? You need the codes checked, try Autozone.
cookie replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can shift by matching speeds of the gears when that happens.
Gas Mileage on Impreza Outback 2006
cookie replied to Franck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you should do a bit better, but not a lot. I live in San Mateo and drive in SF pretty frequently. My Forester averages around 25 normally. In the City a lot and I'm lucky to see 18.
cookie replied to CIS Subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow was the endplay measured? If there is no flywheel on it some engines can move a lot.
why lots of 2001 Outbacks for sale
cookie replied to lynjohn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is just about the time for a leased 2001 to come off lease. Lots of folks figure a car this old is time to trade.
Dogbone???
cookie replied to 01-06 forester's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX97 it would be possible to damage an enigne with a Seafoam treatment. there are two ways I can think, but I have not heard of this for years. people used to remove carbon by trickling water down the carb while holding the throttle open. On rare occasions someone would trickle too much and cause piston slap or full hydraulic lock by stalling the engine solid.
