Everything posted by mcnea001
5EAT Blown Transmission cooler fitting
All: Need to update my sig line but I have: 2005 Subaru Outback LL Bean 3.0 H6 / 5 EAT Transmission 136k My daughter went to the store on New Years day and came right back. She said the car "would not go" I go outside to find a trail of trans fluid from my driveway out and around the block! Upon closer inspection the bung for the trans cooler was completely blown out. My initial thought was rust but it appears that the radiator failed INTO the trans cooler. The resultant pressure increase blew out the fitting. My plan is to put a new transmission filter / radiator / fluids in it and see if she will go. Anything I should do/check that you guys can think of. Pulled dipstick for trans (what is left) does not appear frothy or smell burnt. Thanks! Tom
2.5 to 2.2 Swap possible?
mcnea001 replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you send me the link to the guide. Was searching threads with no luck. Thanks, Tom
All: I have a 1995 Legacy Wagon with 2.2 Manual Transmission. I need to pull the motor out since my clutch has gone bad (again). Cruising FB I found a 2002 Outback Automatic with a seized motor. Can I swap the 2.2 in? Would I just move over the flex plate to mate with the AT? I am reading lots of threads about automatic to automatic swaps but nothing with a MT to Automatic. Any help / thoughts would be appreciated. Tom
New Car!! Sport Light Flashing
Good afternoon USMB friends: Purchased a new Subaru to add to the fleet. Picked up a 2005 Subaru Outback with 115k. Is the LLBean Edition with 3.0 H6 with Automatic Transmission. A needs some odds and ends. The major reason the guy parted with it was the Sport light is flashing causing the transmission to shift at odd points. Only code is C0108. I swapped out the left ABS Wheel Sensor. My questions: 1) How do you reset the TCM codes? Any recommendations on a scanner if I need to purchase a cheap one to do it? 2) Issue seemed to be resolved. Got on it hard to see if problem would occur and hit rev limiter. (Was in auto.) Sport light began to flash. Is this a related issue? (Did not know why I hit rev limiter.) Would having exhaust off cause the issue? Video here: Any help would be appreciated. Tom
2008 Subaru Legacy - worth purchase
Hello all: Looking for a new project and came across a 2008 subaru legacy limited 2.5 in my neighborhood. Link below. Looks like the guy crashed it. Most concerning thing is that he said it lost coolant and it overheated. How sensitive is the 2.5 to overheating issues? Any way to check if it is toast? I can pickup a front clip on ebay for about 1200 but if the motor is toast it is not a good deal. Would appreciate thoughts and any advice. Thanks in advance. Tom https://annapolis.craigslist.org/cto/d/totaled-2008-subaru-legacy/6534339379.html
Fuel smell on startup
mcnea001 replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks all! Tightened up the fuel clamps and no more smell. Easiest fix ever! Tom
Hello: I have a 1995 Subaru Legacy with EJ22 and about 198,000 miles. Car runs great with no starting issues. When I start the vehicle in the mornings (now that it is getting colder) I get a raw fuel smell in the cabin. It smell like fuel is leaking but I cannot find the culprit. Once warm it disappears. No check engine lights. I have viewed a bunch of threads that recommend replacing the Coolant Temp Sensor. I do not have any idle or starting issues so I am not sure replacing the Coolant Temp Sensor will fix the problem. Other threads have indicated it may be the evap canister. How would I troubleshoot that? Any thoughts or ideas would be appreciated. My wife hates the smell :-) Tom
1995 Subaru Legacy AWD - Tow Dolly
Hello all: Looking at a 1995 Subaru AWD on craigslist that needs some love. Super cheap since it needs a head gasket. I own a tow dolly (how I brought home current 1995 FWD). I know I can't tow an AWD on a tow dolly, but I just saw a thread on another website that said the following.... on the older stuff (90's) there's a capped fuseholder in a harness along the firewall on the passenger side of the vehicle. The cap on the fuseholder is labeled FWD. (black holder, white letters, from what I recall) Open the cap, and pop in a fuse, and you're in front wheel drive mode. I don't know what rating of fuse you need, though. Is this true on the 1995? Could I then drag it home on a dolly? Thanks as always for the help. Tom
Low MPG
1995 Subaru Legacy Wagon EJ22 195,000 Miles / Manual Trans All: Need some help with MPG. Car is running great thanks to everyone on this forum. Only problem is that I am getting MPG in the solid 20s. I replaced one of the 02 sensors in May since I was getting a check engine light about 02 temp. CEL went out and I have been driving happy. Complete go through of the car last year. New plugs / wires / fuel filter / thermostat / etc. What am I missing? She does smell rich when it first starts. Thanks in advance! Tom
1995 Legacy Wagon - Fuel Smell @ Start Up
Hello: I have a 1995 Subaru Legacy Wagon. EJ22 / 186K. As it has gotten colder car has a fuel smell @ start up. The fuel smell is coming from the tail pipe and it seems that the car is running rich until it warms up. It has not thrown any codes. I am thinking that the O2 sensors need to be replaced. Any thoughts? Thanks much! Tom
Looking at a new project
All: This just popped up on craigslist today. Sounds like the turbo killed itself. Banjo bolt from my quick google search. Any thoughts? Looks like a VF40 turbo is about 700 rebuilt. Any other things to worry about? Metal shavings in engine / oil http://annapolis.craigslist.org/cto/5323900642.html Tom
Throwout Bearing
All: Just completed my clutch swap about 500 miles ago. Replaced clutch, pressure plate, throw-out. Used the kit from SACHS that includes the sleeve for the throw-out bearing. Things are running fine...but the throwout bearing seems to be getting a little more noisy. You don't hear it when the clutch is pressed all the way in..but a bit of a rattle with the clutch out in neutral. Just wondering if this is normal for this setup with the sleeved throw-out bearing. Any help / thoughts would be appreciated. Subaru Legacy Wagon 1995 EJ22 / 5 Speed 185,000 Tom
Tailgate light will not turn on
All: On my 1995 Legacy Wagon the light in the back of the wagon will not come on when you open the hatch. If you manually turn the light on via the switch, it works. Where is the switch for the light? Is it the two spring loaded pieces on either side of the door on the left /right? They are quite rusty. Any good test for the switches? Thanks, Tom
- Passenger Door Lock
Wheel Bearings
mcnea001 replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry....1995 Subaru Legacy L Wagon. Any concerns with driving it for a little while? Need to save my $$ if I need to do wheel bearings now. Tom
96 impreza won't start
mcnea001 replied to ozstewarts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat motor? Automatic or Manual?
Wheel Bearings
All: So finally got the subaru on the road legally after my clutch swap. Running good but I am hearing some growling. It makes more noise when I change lanes which leads me to believe it is the front wheel bearings. A few questions: 1) Any danger / harm by driving the car around? I want to shake out some of the other bugs.. 2) Anyone have a good how to with pictures? I am thinking of purchases the complete hub assembly. I want to avoid pressing bearings if possible. http://www.1aauto.com/2005-11-subaru-legacy-outback-wheel-bearing-and-hub-assembly/i/1ashf00336?f=518153&y=2005&utm_campaign=gb_csv_br&utm_content=SHF&gclid=Cj0KEQjwy92wBRCl7trx4PaIo8EBEiQASPhtC4DVIZSLnZv3F6WiKRlzHWywONKtGRQAArcfQjWIjlcaAoOd8P8HAQ Thanks in advance. Tom
Speed Sensor
All: So the speedo stopped working today. Threw the code P0500 speed sensor. Pulled the cluster and checked the small connector on the back...pulled left / right / up / down. Tightened the screws on the back of the cluster. And double checked the connection on the speed sensor. No joy. My 1995 Legacy is a MT. According to a vid on youtube it is a 17MM connection. I am planning to go to the junkyard and pull one tomorrow. Any other ideas / thoughts / things I should try? Tom
Clutch adjustment
All: Put a new clutch in my EJ22 Legacy. The manual is not really good about how to adjust it...or it does not make sense to me. I also have the hill holder. I adjusted it out so the pedal takes about 1/4 off the floor. I left a little slack in the clutch fork...and tightened up the hill holder so it will not slip and ride the throw out bearing. I checked up by putting it in second gear with the parking brake on...and it stalled. (It did not slip) Sound right? BTW...I don't like the hill holder. If you are braking while down shifting it seems to keep the brake on a little. I may just need to get used to it. Tom
Knock Sensor wire disconnect/snap
mcnea001 replied to indo1day's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnock sensors usually go bad on these cars. I picked one up cheap from ebay...works great. I would just go ahead and get a new one. Tom
Intake hum when running
mcnea001 replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk...checked around. Looked for vacuum leaks. Checked to make sure flow was not obstructed. Took for a drive. That is when I noticed..when I hit the accelerator...it makes a deep...WHOOOP sound. Almost sounded like the airbox was unhooked. Turned out that someone has cut the bottom out of the airbox under the filter. I am assuming this cannot help the sounds at idle. Why? Should I go to the junkyard and replace. Tom
- Intake hum when running
EJ22 Overheating
mcnea001 replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like it was air...went back out to check to see if bubbles in reserve tank. No bubbles. Filled radiator more...filled reserve tank. Ran it around the block about 10 times....let it idle...stayed right on the middle of the gauge. Should I jack it up to bleed it some more...want to make sure it is perfect. I am looking for what to come out of the drain...just straight coolant? Tom
EJ22 Overheating
All: EJ22 is back in the 1995 Legacy L wagon. Pulled it for clutch / seals / oil seal / etc. Got the engine back in and she started after I followed the procedure for priming oil pump! Tanks fairtax4me. Have lots of other question...but the most immediate. Car is getting hot. Was putting fluid in it...and it ran for about 10 mins....went to take it up the street and it moved to H quickly. Also took the cap off and it was pushing fluid out the cap. This car is new to me. When running before did not overheat (in driveway). Oil looks fine. Please God don't be a head gasket after all this work. Anything I am missing here....does this sound like I need to burp the coolant? And what is best way to do that...saw some other threads. Concerned in Annapolis ;-) Thanks, Tom
Drivers Side foot well wet
Well I have put the motor install on hold since it has been raining since Tuesday. Today I was grabbing a tool and noticed the foot well on drivers side is wet. Car is on jack stands and tilted back. Would this be the windshield seal? Just re-seal with more silicone? 1995 Subaru Legacy L Wagon
