Everything posted by ron2368
Fan slider blowing fuses
I have a 92 legacy sedan and have both fan fuses(25a) blow. If I slide up to 3/4 full power the fan will not make a sound then sliding it a tiny bit more the fan will run for 1 second then the fuses blow. Is the switch bad? I have a haynes manual but it does not give any info on the switch or how to get to it. If its bad can I replace it easily, does not look easy to get to or is there a way to bypass it for now? 2nd question, my speedo cable is noisy when the car is cold can I lube it?, does not look easy either, any easy fixes? thank you
problems with heater blower
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did the test at least 3 times, there is no voltage to the fan. I checked the fan resistor per the manual and it was ok. The wiring diagram shows a bl/red wire that goes to the relay from fan. I can follow it up to a large mass of wires where it looks like it turns left. Yes there are two plastic small boxes right next to eachother one has 2 or 3 wires the other has 5 so I guess I will find out when I get the part. The fan wire is fairly thick but the wires to these boxes is much thinner, hope it does not matter.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the wrong part, I liked it since it was 8$ , the correct part is 90. Its r6154 , I am going to check the plug pattern before ordering Later that day> plug pattern was wrong so I ordered part from local subie dealer. They used vin to find part so hopefully it solves my issue.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still cant find the relay, the part I have is 35767 and is a air conditioning relay. I see other boxes under the dash but they are plastic and the one I have looks like it should be out by the engine, though I still cant locate it there.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a new relay, I tested the voltage at the fan clip and there was none.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked under the dash for the relay and could not find it, is in engine compt? My manual mentions it but does not say where it is.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI now remember that about 2 years ago the fan had a problem where it would not work when the car first started up but after a few bumps it would work fine. For the last year it was ok every day. When I replaced the old fan 2 weeks ago it was totally dead, I plugged the new one in and it ran fine, so I that the old issue is related to the current problem but I cant be sure. I will have a voltmeter tomorrow, do I test the voltage across the plug? Does it vary with the fan settings? Will also test the resistor, it says to test across the contacts, but which ones? I think there were 4 or 5 of them, just pick one and test the others against it? Thank you for your help, I need it!
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe motor I got from the parts guy died after a week, so I am looking to do motor #3 now. I think I have something to test voltage will get back when thats done. thank you
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, if the motor is on a fuse wouldnt that regulate any overvoltage. thank you
I have a 92 legacy, two weeks the heater blower died, it had a noise for the last 5 years, Last week I replaced it with a used unit, that I cleaned up and relubed the the shaft bearing area with some grease it ran great for a week. today that motor is now dead. Is there something that could make this motor go bad, the fuses are ok. Before I spend 80 on a retail motor I thought I would ask. or is it bad luck?
92 legacy A/C charge
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo , I dont have a hose, the side can tap they sell does not look like it will work unless I use the refill upside down which I think is bad. I cant find anything locally on CL.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was looking at a product Freeze 12 but its listed as a substitute or replacement so I guess mixing it is not good. Usually you would buy a can with the fitting/hose and no one sells both anymore and that makes it more confusing.
I dont think I have ever put any in since new, it still works good but it needs a bump cooler. When I look at the round glass on the ac part it has a slightly foamy look not a clear liquid look. I called a shop and they made it sound very complicated and dangerous plus expensive. If anyone has ideas please, I would appreciate. thank you
brake job with caliper problems
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe piston was frozen, there was no leak or damage I could see. Since I was able to move it back does that mean it will work properly? Or since it froze is it surely conidered broken?
I put new rear pads on my 92 legacy fwd. The driver side piston was frozen, though there was no damage or noted wear to the brake pads and no leaks. I did manage to use some strong leverage and release the piston so I could finish the install. I assume that that wheel has not been braking for a while since the piston was so locked up, but I have not noticed any change in stopping . Is the caliper broke or since it was frozen will it work properly. I asked one person and they said since it froze it has to be replaced. I was looking at the advanced auto website and they sell loaded and semi loaded and some that say nothing about that, which would I need? thank you
Is my engine slowly dying?
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have no idea about the specifics of testing it . I am going to keep running it and treat it with tlc . I dont drive it regularly but when I drove it home I think it runs fine. Sorry I dont know more but thats why I come here. Wish I could do all this kind of work but its not in my future. many thanks.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you all, the car is my daughters college driver about 20 miles rt . The trans is also slipping a bit so my plan is to drive it till it dies. My guy said it could last a year. I will slowly look for a replacement. It will need new tires but thats about it. I purchased it new and it has about 140 k on it so its got good use. As far as the repair its way beyond my ability both physically and mechanically. Just not realistically a weekend job for me .
Took my 92 legacy 2.2 fwd to the shop, it has an erratic idle at times, if I rev it the idle drops almost like it will stall, but it rarely does. The word was that #1 cylinder is at 70% power, probably leakage around the valves. The head job was quoted at $1100 but not recommended. How long can the car last like this? Also is there anything I can do to delay its demise? thank you
2006 legacy radiator drain ?
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked, didnt seem easy at all. Will look again.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks, I may put a 1/2 inch hole in the shield below the drain so I can get to it fairly easy. I probably would have to take the shield off to remove a hose.
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I have to remove the shield under the radiator I would rather not fool with the hose / clamp. I can feel the drain area and the plug feels like it would unscrew with a flat tip screwdriver does that seem possible? There is only 3 inches down to the plastic shield so it is hard to get at it from the bottom. thank you
I want to change the coolant. Do I have to take that large plastic skirt off under the engine to get to the drain? When I go in from the top I cant see or feel a drain area, there is a round plastic area that hangs down off the bottom corner, is that where the drain is? Is it opened with a screwdriver. Sorry I just dont see any obvious drain and dont want to start taking things apart without checking with the experts here first. Thank you
idle problems for 92 Legacy fwd
ron2368 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did that a a couple of months ago along with cleaning the pcv, but I will give it another check, thank you. I usually spray carb cleaner in and use a small rag to wipe the area so I can see how dirty it is, is that ok?
It is infrequent, mostly after the car is running 1 or 2 minutes. the idle will just drop instantly when the car is brought to a stop, usually the idle recovers and stays fine, rarely it will stall, but will restart afterwards.. I was thinking of doing plugs / wires, it has a new gas filter about a year ago. Just looking for some ideas to approach this. Thank you
trans drain and fill with hd is good!
ron2368 replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a car at 60k and I am wondering if I should have a drain and flush rather than just diluting the dirty fluid . Can a garage do it or only a dealer? There are many good ATFs should I only use subaru( car is out of warranty at 60k). How about these 15$ a quart ones like royal purple?
