Everything posted by Andyjo
I average ~25mpg with all my roofracks on (3 thulebars, 4 lights on top) i get ~27-28mpg with the racks & lightbar off. This is all the same drive, same gas station fill up, etc... Today when i filled up, i got ~12 gallons and had gone a little more than 330 miles on that tank, according to the gps (my tires mess w/ my odo.. so i ignore it.) with the racks on i can get about 280 miles on a tank. 97' OBS, EJ22, 4eat, 176.5k
So, i'm getting a WRX exhaust for my OBS... which has a set of 2" borla headers coming from the block.. my question is if i want to go from 2" to 2.25", can i just made an adapter flange? I drew it up in solidworks... would this really mess w/ the flow? or would it work? Bending a pipe shouldn't be that hard If i just have a chamfer on the hole... to the correct size.. that would work, right?
Ouch. It's not supposed to look like that.. right?... doesn't the baja have it's air intake right above the radiator too? so that bow wave just goes right in? :-\
Any interest in a North East soob offroad meet?
Andyjo replied to 75subie's topic in Meet n' Greet. Your USMB Welcome Center
It's 391 Miles to get there for me.. so.. ~6-7 hours, not too shabby i may also have to convince my girlfriend to come, i'm thinking i'd leave friday and campout somewhere friday night.. or stop in CT at one of my friends places. -
Yeah... i'd do something w/ that tire bouncing around Awesome photos!! i like how you can see the flow over the cars w/ the sand & stuff good stuff!
changing the tranny fluid on an auto is really easy... just pull the plug out... drain it (i bet the fluid will be nice & black.. chunky maybe?) , once it's empty, plug her up again, dump some more fluid in, and drive around a bit... then do it again... maybe a few times... it's cheaper than having a mechanic do it Hey Nippster, where did i put my keys?!?! argg...... And grossgary.. do you have a spare fuel temp sensor i can buy from you? I get alot of PM's about the stuff i wrote, about the lifts & 4eat clutch pack lockup... always like being helpful
I'm sure Jamie could hook you up with one. I'd try some good ol' copper/silicon RTV or something before buying a new one... i mean.. the hole in my oilpan is STILL being held by that stuff! (2k later...) RTV is just a gasket material... you put it on your gaskets & stuff, then clamp everything together, and it'll set, making you a really nice seal. You can get the stuff anywhere... hardware store, auto store... just ask for gasket maker stuff.
so its been awhile since I posted any video....
Andyjo replied to nicky nighteyes's topic in Off Road
i want trails like that here!! i also need some more clearance and a d/r... but whatever -
ohh.. that... just pry it off i think... when i changed mine i think it just fell off... i don't think it's pressed on or anything
The big shiney (sometimes not so-shiney) nut? yeah, it should slide right out of the bearing there.... the spring & top that is... as for the perch.. it's welded to the strut.. it's not going to go anywhere.. the rubber boot thing will most likely come off.
June 15th.. or July 15th? June 15th = Thursday July 15t = Saturday -
Only when going slow? i'd check your tranny fluid just incase... it can never hurt to change out the fluid anyhow You may also want to check the temperature of your wheels/brakes after you drive with it... and it'd doing this, maybe one of your calipers has siezed? If it helps you any, my impreza shakes alot at about 55mph :cool: but i know that's an allignment issue.... edit: Oh yeah, an axle going bad COULD do that also... and maybe allignment... but thats usually high speed that'll get yah'
i haven't done it.. but i've been thinking of bracing up the front end, cutting off the rad. supports, and then welding in some 2x2" 1/8" wall square tube in there.... a bit higher, there's about 1-2" of room you can move the radiator up before you start running into issues shutting the hood
Official New England Meet
Andyjo replied to Seahag1978's topic in Meet n' Greet. Your USMB Welcome Center
How was it? it sure was raining in VT :-\ Although i didn't get to make it to the meet... i did manage to suck 28mpg out of the impreza -
He was also floating towards the end there
Be careful when you do that.. or else you end up like me
Arn't the splines different from the 4eat to a 5MT? i don't remember where i might be remembering that from.. .but.. yeah..
Depends on how quick i get my king springs... i may be up for a 3 if i get those -
When i installed my lift.. i kept on running out of directional fluid had to seal up some things
