scoobydube
    5
Everything posted by scoobydube
  1. The fix is to jack up the car at the hinges with both front and rear wheels off of the ground. Then put one person on the front bumper and one on the rear bumper area, and bounce the car until you bend the frame back to where it used to be. Do only a little bit of bouncing at a time, and then recheck.
  2. It depends on your winter time temperatures. If you regular drop below 20 degrees F in winter, then that 5W -20W would be a good oil in winter. In summer, back to the 10W-40W for me.
  3. I bought a set of the LED headlight bulbs that was deemed directly compatible with my OEM headlight bulbs. Big mistake. My digital dash went haywire and the engine began cutting out and otherwise ran poorly. Then the below dash relay switches were overheating and burning out. Finally, I realized that those LED's were screwing up my car big time, but only after I changed out my distributor, coil, cap and fusible links in a rain storm. Now I am back to the the OEM bulbs, have installed all new relay switches, and keep a handful of spare relay switches to pop in if I have any further problems. 524,000 miles on my 86 gl10 turbo.
  4. Yes, the original trim was a T-type with a very shallow embedded portion. It still is a source of a leak. Don't use any trim. Form the new trim with RTV sealant and your windshield won't leak.
  5. Sure, grease will hold it in place for assembly. But what I was referring to was when the engine oil heats up over and over again, it expands the rubber of the seal and then causes it to buckle inward and break the oil seal, causing oil to leak out onto the oil pan and drip onto the ground at a prolific rate.
  6. If you are talking about the outer trim corners, you don't need them because you can shape them by filling in the corners with RTV sealant and using painting tape to form the round edges.
  7. BTW, you don't need to change the rubber seal. It is the outside trim that is the impossible to find and generally defective design that you would want to use RTV sealant as a substitute while you are using it as a base to set the windshield on.
  8. You could buy 2 of them and chop them up to piece them together and get a complete fit. The windshield sets on the sealant, which auto supply shops do not sell the primer,so the sealant won't stick to the frame if you don't use the primer. The trim is not available either so you either have to use your old jagged pieces or just use the RTV black sealant to make it look like you have trim. The worst of your problems however, is the metal windshield frame at the base/ bottom/front of the windshield, which is usually mostly rusted out. Hopefully you have enough remaining to hold the BONDO GLASS that you are going to use to restore the original tray shape and allow that Bondo to seep through all those holes and the catch the flow through with a sagging duct tape form in order to provide a mechanical attachment for the Bondo to the metal frame.
  9. I accidentally discovered my oil leak when I changed out the oil pump. The old mouse eared gasket again got hot, expanded and buckled inward, so as to then pump oil straight outside of the gasket containing boundary. For my new mouse eared gasket install, I RTV'd the offending portion of the gasket in place, so that it cannot buckle and leak. My mysterious engine oil leak then completely disappeared.
  10. The T-type trim is inherently leaky since the embedded portion is a pathway for the water to find the bottom edge of the glass, causing a leak. I used RTV black silicone along both the top and bottom and kept the factory trim look by using some paint edging tape to make a perfect edge. Although I reused the corner trim pieces, I would not have needed to since I also could have produced a perfect corner with the edging tape and RTV. The original trim is no longer available anywhere. You can get some T-type trim from Rock Auto, but it is going to cause a leak. The bottom edge of your subaru windshield frame is probably rusted out pretty good. You can reform the original metal frame with BONDO - FIBER. The holes in the existing trim will allow the bondo to flow through and get a grip on the old metal. You can form the bottom free edge of your new drippy Bondo, with some duct tape that you allow to sag between the edges so as to form a continuous back side surface that keeps the new upper flat Bondo surface in place.
  11. As a follow up to the above T-moulding suggestion, the deeper the embedded portion of the T is into the caulking, the more likely that not only is a leaky window going to happen, but the bottom metal shelf that the exterior plastic panels sit on, is going to rust to the point of having many small holes. If it hasn't already rusted. Cars that sit outside in the rain year round, are guaranteed to have rusted bottom shelves. Certified window replacement shops will not replace windshield with any of those small holes. So once they discover them, they stop work and you get to pay to have your car towed home. The solution at the bottom shelf, is to cut out all the trim and old caulking and then form round bottom formwork out of duct tape beneath the shelf, and then trowel bondo with fiberglass onto the bottom shelf so that it flows through those holes and forms a level top surface outside of the glass edge. Now you could go to a certified window replacement shop at this point, but they are just going to screw it up again unless you give them specific instructions. Those instructions are do not use any T-type moulding for either the top or bottom edges of the windshield. Use RTR or the black caulking that you buy in the auto shop. Form both edges of your caulk line in advance with electrical tape so you get perfectly straight lines and it looks like real moulding. For the side, you can get away with the T-type moulding embedded in the RTR caulking since leaks there just run downhill.
  12. Leaving the engine in the car is the best way to get the highly torqued cylinder head bolts loose and retorqued. The secret trick for first timers is that there are 2 lengths of cylinder head bolts because there are two shoulder heights on the cylinder heads. If you put the short bolts in the tall shoulder holes, then you are going to strip out a bit of thread in the block. You can correct it though by going back to the long bolts in the tall shoulder holes and still get enough torque on the bolts. Felpro is the only way to go for head gaskets.
  13. After searching and searching, the closest I could find was the Rock Auto Metro LP 100-Z windshield moulding/seal. It is a T-type moulding. I could not find any kits, nor corners.
  14. The fine tip platinum plugs go bad real fast so you might want to check the plugs. Inside of the distributor cap, the 4 pins that send the spark out to the plugs, get corroded every 5000 miles and need the corrosion cleaned off with sandpaper. The plug wires get corroded inside of the connectors at each end. The engine ground wire goes bad at the connector to the body at 200,000 to 250,000 miles.
  15. I bought an after market steering rack off of EBAY and it fit and works perfectly.
  16. You need a new cylinder head. When they crack, they usually spill coolant into the exhaust at a couple of places. But oil is pushed through the cylinder head as well. You may have driven it too hard.
  17. If you haven't fixed it yet, replace the headlight switch because it controls several different lighting features and indicators.
  18. Try replacing the O2 sensor in the catalytic converter. They can suddenly go out and really screw up the engine. They are cheap and it looks like it is about time for a new one.
  19. Does the rotor spin when you crank the engine? If not then you broke the left side timing belt. Can you get spark to the plugs as a timing light will show you, by plugging into each plug wire and grounding to plug? If yes, then you can check the timing at about 24 degrees BTDC, for No. 1 (front right) cylinder. Best to put some white paper white out paint on the 24 degree mark first. If you cannot see the white mark then your timing is way off, perhaps the timing belts jumped a tooth. The GL10 distributors have a short life expectancy. Better find a backup to always have on hand and to install here. If you have no spark and the rotor spins, then you probably have a bad cylinder. Buy used from John's Subaru in Laurelwood, Oregon, or get hosed on Ebay. Wires that get hard, brittle and stop conducting electricity are the hot wire into the back of the alternator, the engine ground wire at the body end, and the hot wire from the hot battery terminal wire to the bottom of the fusible link box (at the terminal wire end). The timing probably got off somehow, perhaps from the timing belts loosening up that allowed the timing belts to jump a tooth. Adjust timing belt tension in the front rubber pop out covers, with a 12mm socket, and don't lose it inside of the covers.
  20. You did not mention how many miles that it has. I would buy a new coil and throw that on. I would also take apart the distributor and see if the vacuum advance system is working properly because the tiny slide plate bearings start to carve grooves in the plate that they contact, causing less than desirable action. There are three wires that get hard, brittle and lose their ability to conduct electricity. One wire is the engine ground wire where it contacts the body. The second wire is the one that comes out of the back of the alternator. The third wire is the wire that come out of the positive battery terminal wire and goes into the bottom of the fusible link box. Those sections of wire will need to be replaced after 200,000 miles.
  21. Item 12. A broken wire to either coil terminal will keep it from starting. Bonus #2: A failure to switch into 4WD can be caused by either a failure of, or disconnection of, either one of the two vacuum pumps on the right side of the engine compartment, just behind the air filter in the 86 GL10.
  22. Single defective items that can by themselves keep the engine from starting and has put thousands of Subarus in junk yards: 1. the black fusible link is the main engine but any of them can start to break or get hard and brittle, causing intermittent and then total failure. 2. the thing a ma jig that bolts to the body, directly behind the fusible link box, that had one wire to the coil and the long black wire running to left side engine attachment next to the battery, where the ground wire attaches. The thing a ma jig also keeps static off of your radio and right before it blows, you get a lot of radio static. 3. the main engine ground wire get brittle and loses most of it's ability to conduct electricity and ground out the engine, at it's attachment to the frame. This single defect will cause the engine to run poorly when you operate any other accessory on the vehicle. For instance, you can almost kill the engine by operating your electric windows, if you have them. THIS IS THE MOST PROBABLE CAUSE OF YOUR PROGRESSIVE FAILURE. These wires may not last more that 250,000 miles. 4. a loose wire inside of the distributor cap 5. the short wire between the Positive battery terminal and the fusible link box, gets hard at the terminal end, brittle and loses most if not all of it's ability to conduct electricity, causing poor performance before a total engine failure. You splice in a new lead to the battery terminal, by splaying both ends of the two wire ends that you are joining, in order to get the maximum about of contact surface. 6. the distributor electronics just suddenly went out. 7. the hot wire that runs into the back of the alternator, gets brittle, hard and breaks, causing the engine to perform poorly before it suddenly fails. 8. bad plugs will cause your alternator to fail prematurely. Some plugs require replacement every 15,000 miles. 9. coil failure or corrosion inside of the lead wire from the coil to the distributor. 10. Bonus: a failure of the replaceable round switch below the dash board, to the left of the steering column, will cause the interior fan to suddenly fail, especially if you had just been running it at it's maximum speed. There are about 5 of these identical switches below that dash in the same location so you are going to have to get a known good switch and plug it into each switch socket, one at a time, before you find the burned out one. There may be black discoloration on the burned out one.
