Chef
Everything posted by Chef
Probably the rod that connects the wiper assemblies under the cowl has either shifted or loosened. Usually caused by too much exertion on the wipers, although I've only ever seen it happen when physically pushed. Not too familiar with the mechanisms myself, but removing the cowl should probably make it evident if you're handy. If not, probably a cheap fix at the shop. Good luck, Chef
For mine I used my haynes manual to trace the wires, as I could not find a universal connector for my aftermarket POS stereo. I distinctly recall a wire for power antenna. Can't speak for newer legacies though, but I imagine it to be the same. Probably a bad connection between the stereo and antenna I imagine.
Wheel Bearings
Chef replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Are they being packed with grease before being installed? From my understanding subaru bearings come with "shippng grease" meant to protect form corrosion, and need to be repacked in bearing grease before being installed. There seems to be some confusion about this even at dealers. Worth checking into. I'd definitely go back to the shop that did and ask them what their procedure is, and if they omit the part about packing with grease, I'd tell them how it's done and have them do it for free this time. -
trouble starting
Chef replied to scofomo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'd suggest the issue is most likely starter solenoid contacts. As for your radio dying during braking, probably a separate issue. Sounds like poor radio contacts too then. The connector behind it might be jiggling while breaking. -
So just to clarify, 2.5 downpipes match those from a 2.2 engine? i.e. I could replace mine and the converter with used ones from a 2.5 and have it fit? Just how much of the 2.5 exaust system fits the GC? Because finding used 2.2 legacy parts here is rarer than hen's teeth, but 2.5 parts are a lot more common.
trans fluid
Chef replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Grumpy?! :-p I did not realise that the container states they were interchangable. I was simply referring to what the owner's manual states. Whew - that was confusing! But I think I'm clear now. -
coolant question
Chef replied to hogweed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Should be no need with a 2.2. Given the age of the vehicle, you wouldn't want to clog any gummed up passages in the rad or heat core (not sure if this "conditioner" acts like a stop leak or not). I'd just get some fresh coolant in there and be happy with that. -
Yeah, sounds like an HLA to me too, but oddly loud and persistant. I'd isolate which side it is coming from and open the valve cover. Maybe a bad spring on one, or just bad varnish buildup. Since it goes way with high rpm, it seems to get unstuck at those speeds. Or an oil passage to it is partially clogged, and high rpm manages to push enough oil past. Either way, a necessary check. Good luck.
My solenoid C problems are quite intermittent, and generally only appear on weekend (no particular reason). The flush had no apparent effect for me, but that's not to say it can't be effective (and obviously is for many people!). I intend to live with it until it worsens to the point that I either get up enough courage to fix it myself (not preferred) or simply unhook the driveshaft and live with FWD.
Key problem
Chef replied to cougdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Any previous symptoms of stickness? If so, probably the lock cylinder finally crapping out. Is it stuck in solid, or is there some play? Personally I'd try some graphite spray (get that plastic tube in there!) and try to pull the key in and out gently if there is some play. -
Not true. Copper is a better conductor, platinum and gold just don't oxidise like copper does and therefore make better conductors in the long run. This is why the change interval for platinum plugs is longer than for copper plugs. But in terms of better spark, copper plugs are your best choice. If I have to replace them twice as often, so what? They're cheap. and better. Go figure.
A way to tell if the fuel pump is working is to turn off all accessories and the stereo, and turn the key to the ACC/on position (do not start it). You should hear slight whir noise from the rear. That means the pump is building pressure to start, and is probably fine. If yours is a wagon, the fuel pump is probably found under the floor mat of your trunk on the passenger side near the rear seat bench. If it is a sedan, you'll have to remove the rear seat. There is a metal cover that is easily unscrewed and an electrical connector sits on top - unclip it (it may stick, and be covered in a mouse nest like mine was). The fuel filter is under the hood. Look to the right hand side of the engine to the upper left of the windshield washer reservoir. Unless the impreza is much different than the legacy, a black can like object should sit there with fuel lines entering it. the lines are probably clamped on. Do NOT remove the lines until the fuel pressure is bled out. Either let the car sit overnight, or unclip the electrical connector to the fuel pump and start the car. It will stall eventually. Even then it pissed fluid out on me when I changed mine. Have many rags handy. If your fuel filter is clogged, there is probably a LOT of baack pressure built up. Make sure when you install a new filter that you have the inlet and outlet lines hooked up proper, or you will have problems! This instructions are good for a 1990- 1994 legacy, and probably similar for you. Good luck.
trans fluid
They are different enough that subaru recommends dextron. Even if there is no real difference, why take that chance?
