Everything posted by Chef
Strange wiper problem
Chef replied to TheBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably the rod that connects the wiper assemblies under the cowl has either shifted or loosened. Usually caused by too much exertion on the wipers, although I've only ever seen it happen when physically pushed. Not too familiar with the mechanisms myself, but removing the cowl should probably make it evident if you're handy. If not, probably a cheap fix at the shop. Good luck, Chef
trans service question
Chef replied to hogweed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich is a screen only, no tran filter on the 4EAT prior to 97 I believe.
98 Outback Power Antenna Stays up???
Chef replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor mine I used my haynes manual to trace the wires, as I could not find a universal connector for my aftermarket POS stereo. I distinctly recall a wire for power antenna. Can't speak for newer legacies though, but I imagine it to be the same. Probably a bad connection between the stereo and antenna I imagine.
Wheel Bearings
Chef replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre they being packed with grease before being installed? From my understanding subaru bearings come with "shippng grease" meant to protect form corrosion, and need to be repacked in bearing grease before being installed. There seems to be some confusion about this even at dealers. Worth checking into. I'd definitely go back to the shop that did and ask them what their procedure is, and if they omit the part about packing with grease, I'd tell them how it's done and have them do it for free this time.
Another clarification on 2.5 to 2.2 swap regarding exhaust.
Chef replied to srponies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, I said GC, meant legacy (1992 in my case).
trouble starting
Chef replied to scofomo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd suggest the issue is most likely starter solenoid contacts. As for your radio dying during braking, probably a separate issue. Sounds like poor radio contacts too then. The connector behind it might be jiggling while breaking.
shuddering when turning
Chef replied to hayden 96 gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're in the UK or somewhere with a right hand drive I take it? Perhaps these were matched differently there.
Chef replied to srponies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo just to clarify, 2.5 downpipes match those from a 2.2 engine? i.e. I could replace mine and the converter with used ones from a 2.5 and have it fit? Just how much of the 2.5 exaust system fits the GC? Because finding used 2.2 legacy parts here is rarer than hen's teeth, but 2.5 parts are a lot more common.
Intermittent Squeal at freeway cruising speed
Chef replied to anne_gillihan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine certainly squeaks and creaks like crazy when chilly, especially when I first got it last feb. But it doesn't seem to creak as bad anymore. As for this squeal, possibly the air fan? Sometimes something gets caught in the air vent system like a leaf and makes odd noises.
Impreza stoped moving
Chef replied to JordanR693's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood luck!
Subaru Hesitation Problems
Chef replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a classic case of plugged fuel filter (or air filter for that matter). I assume these have been changed though...
trans fluid
Chef replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGrumpy?! :-p I did not realise that the container states they were interchangable. I was simply referring to what the owner's manual states. Whew - that was confusing! But I think I'm clear now.
The Inevitable Wintertime Legacy Air Conditioning Question
Chef replied to subiedoobiedoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 1992 is still R12. Someone put a some dye in it a eyar and a bit ago before I bought it to test for leakage, or so the little yellow note attached tells me. Also says do not refill.
Chef replied to JordanR693's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the problem is highly intermittent it might also be a plugged fuel screen inside the fuel filter. material from the gas tank might accumulate and clog it while running, then fall off when not. Especially likely if you run the tank down often. But try the fuel filter first.
ngk's or oem? pcv valve?
Aww, no one meant anything personal. Stick around, we like you around here! Most of the best gear-heads around here frequent the old-school forums.
coolant question
Chef replied to hogweed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be no need with a 2.2. Given the age of the vehicle, you wouldn't want to clog any gummed up passages in the rad or heat core (not sure if this "conditioner" acts like a stop leak or not). I'd just get some fresh coolant in there and be happy with that.
EJ22 - Diagnose This Sound! (Video!!) 1991
Chef replied to NuclearBacon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, sounds like an HLA to me too, but oddly loud and persistant. I'd isolate which side it is coming from and open the valve cover. Maybe a bad spring on one, or just bad varnish buildup. Since it goes way with high rpm, it seems to get unstuck at those speeds. Or an oil passage to it is partially clogged, and high rpm manages to push enough oil past. Either way, a necessary check. Good luck.
Seatbelt Problems on a 1990 Legacy Wagon LS
Chef replied to Uber Subar Man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhem. http://www.ultimatesubaru.org/forum/showthread.php?t=51746
Chef replied to subiedoobiedoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot an option on the old-school refrigerant AC used on the 92 I'm afraid.
Engine sounds like its comming apart....
Chef replied to soobcollektor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe mentioned he car has already had the recall performed on it. I dunno, sounds like a failing knock sensor or bad timing for sure. Either that or some sensor ECU malfunction. The intermittent nature of course makes it even more of a PITA to fix.
Chef replied to hayden 96 gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy solenoid C problems are quite intermittent, and generally only appear on weekend (no particular reason). The flush had no apparent effect for me, but that's not to say it can't be effective (and obviously is for many people!). I intend to live with it until it worsens to the point that I either get up enough courage to fix it myself (not preferred) or simply unhook the driveshaft and live with FWD.
Key problem
Chef replied to cougdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny previous symptoms of stickness? If so, probably the lock cylinder finally crapping out. Is it stuck in solid, or is there some play? Personally I'd try some graphite spray (get that plastic tube in there!) and try to pull the key in and out gently if there is some play.
Not true. Copper is a better conductor, platinum and gold just don't oxidise like copper does and therefore make better conductors in the long run. This is why the change interval for platinum plugs is longer than for copper plugs. But in terms of better spark, copper plugs are your best choice. If I have to replace them twice as often, so what? They're cheap. and better. Go figure.
Chef replied to JordanR693's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA way to tell if the fuel pump is working is to turn off all accessories and the stereo, and turn the key to the ACC/on position (do not start it). You should hear slight whir noise from the rear. That means the pump is building pressure to start, and is probably fine. If yours is a wagon, the fuel pump is probably found under the floor mat of your trunk on the passenger side near the rear seat bench. If it is a sedan, you'll have to remove the rear seat. There is a metal cover that is easily unscrewed and an electrical connector sits on top - unclip it (it may stick, and be covered in a mouse nest like mine was). The fuel filter is under the hood. Look to the right hand side of the engine to the upper left of the windshield washer reservoir. Unless the impreza is much different than the legacy, a black can like object should sit there with fuel lines entering it. the lines are probably clamped on. Do NOT remove the lines until the fuel pressure is bled out. Either let the car sit overnight, or unclip the electrical connector to the fuel pump and start the car. It will stall eventually. Even then it pissed fluid out on me when I changed mine. Have many rags handy. If your fuel filter is clogged, there is probably a LOT of baack pressure built up. Make sure when you install a new filter that you have the inlet and outlet lines hooked up proper, or you will have problems! This instructions are good for a 1990- 1994 legacy, and probably similar for you. Good luck.
trans fluid
Chef replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are different enough that subaru recommends dextron. Even if there is no real difference, why take that chance?
