jxavierf
Everything posted by jxavierf
  1. Thanks for the advice.....but not quite sure how to go about it (not well schooled in mechanics, but trying to learn)...could decribe what you did in laymen terms. Cheers! xavier
  2. I have an 84 wagon 4x4 (36k) automatic with some problems. First, trouble starting. Second, must let it warm up for at least 5 minutes before I put it into gear or it will die. Third, once warmed up, and I press the gas pedal, the RPMs sink to the point that if I'm not careful, the car will stall. Forth, once its been running for around 10 minutes it runs great....very smooth, however, the RPM's meter on the dash starts fluttering......it will go from 2k RPM's to 3k RPM's and then go to normal. I've listened to the flittering and pinpointed that it was the distributor making the noise.....though I not sure that the distributor is really the problem. I've been to a mechanic who tuned the carb but said I need the following: Start Relay, Check Valve, EGR Valve, Idle Solenoid Valve. If any of you have any suggestions, please let me know. If you think I do indeed need these parts....where do I get them???? Thank you in advance. Xavier
