Everything posted by roger1
95 Legacy 2.2 - check engine light on
roger1 replied to DaveTV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same model year, several years ago that happened to me. I went to local repair shop had them put on computer ($65) and gave me a componet that was faulty. Had to go to dealer for the $35 part,went to library and found componet location on engine. Replaced it and as been good ever since. I drove it several months with no apparent (to me) performance before I did anything about it.
attempting a head gasket job
roger1 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy OEM belts had marks on them to help with timing. Sure made it easier, when I turned the engine through it was right on! Has anybody found marks on after markets ones like Gates? I used some webbing over pulley when I used the chain wrench as I had to file kicks off I made during removal.
Intermittent headlights on 01 OB
roger1 replied to shorinjin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a problem with our 95 Legacy, headlight out, replaced the bulb, 2 weeks later same thing, replaced bulb and nothing. The socket the bulb was plugged into crumbled (from heat?) Spliced in new socket and no problem. The socket wasnt obvious the first time. My 2 cents!
Should I Buy a '95 Outback?
roger1 replied to mkp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will pass on the selling price. The sending units (2) are easy to do,pull up mat in cargo area remove plates (2) If AWD. Cost about $90 each at dealer. Go to locksmith for rear hatch. That is normally a 300K engine on normal maintanence. This includes radiator coolant replaced every 2 years. This is probably a 2.2 engine none interferce design, 2.5L is interference type prone to headgasket problems. Are you sure its valve cover gaskets and not head gaskets? Rotate tires and or replace to keep circumferecnes identical for the AWD. They are slightly more unique that other inline engines so find a mechanic that is knowledgable. My wife bought another after 18 years of an 80 with original engine and tranny with 210K miles . Has a 95 AWD legacy now for 5 years.
Stuck oil drain plug
roger1 replied to Huffer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX[i had the same problem with my old Mercedes and a mechanic fro germany said give a good rap with a hammer on oil plug. Never was frustrated again!
Help with cam seal, crank seal, water pump & oil pump service on 96 2.2 Legacy Sedan
roger1 replied to johndub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe biggest problem for me was loosening The stud for the cranksahft pully. I bought a chain wrench that helped alot. It knicked the pulley and I filed off the burrs. Tightening it I put a piece of webbing to prevent that. Other folks put socket and breaker bar on and hit the starter momentary to "crack" it loose. If you have a remote starter that would make it easier for me. Put on new belt and note marks for the timing on belts. (At least on OEM ones) If after market one don't have marks ,pass, because it so much earier withe marks. All of previous post had good advise. my .02 cents
Timing cover seals - adhesive or sealant?
roger1 replied to bearbalu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAssuming you are talking about 85-89 engines, none are required Unless engine has gotten hot to melt and sag? Then you have to decide what you need to do to patch it up. I would use a none hardening type because you need to get them off to swap timiing belts. Sometimes a spot of wheel bearing grease will hold something in place during assy. MHO
Power Windows
roger1 replied to silverflash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf lubing doen't fix your problem, clean contacts on switches with contact cleaner and non abrasive cloth . On older ones they had small springs so work in area you won't lose parts. Worked every time for me!
crank bolt
roger1 replied to patcal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used a chain wrench I bought from Northern tool for <> $20. Use some fabric strapping or thick leather to keep knicks from teeth of wrench from damaging pulley. I was able to grind them out with the pulley in hand but added the protection when reassembling. This made it easy for me alone to torque it during reassemably
79 Brat speedometer
It doesn't have a Tach! I'll see how my time goes on pulling it out. The heater was by-passed and I need one that doesn't leak! Any help? thanks
I am thinking about buying a 86 wagon with a bad drive axle
Go yo www.cvaxles.com for a replacment! I never known one to tear up tranny, but never drove one till it quit! If it's noisy going straight it's probably inside joint as outside's on make noise on power into corners.
79 Brat speedometer
Just got it running again, but the speedometer doesn't work but odometer does. Any tips that I might do other than a shop? THANKS
Removing timing belt on Lecacy, what tools needed?
roger1 replied to coloradosubarules's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid your belt have some marks on to get the proper number of belt teeth between cam pulleys and main gear? The haynes book was very good about the count and on my OEM belt they had marks that was a big help which I discovered by DUMB luck. If it runs you cannot be very far off. On my 86 I thought you could tweek dist and 1 tooth wasn't a problems. NO WAY!!!!
roger1 replied to coloradosubarules's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe chain wrench sure was a big help with loosening the stud that holds pulley. put piece of webbing or leather under to prevent nicking pulley. Belt tightener compresses very slow in vise(2 -3 minutes) a little at a time. Mines a 2.2 l 95 model. I used Haynes manual with OEM parts and worked fine. Timing belt had marks on for timing the cams and main pulley which made it easy. You can count the teeth and mark it too if it didn't have it. Hope I'm not too late!
CV Joint replacement
roger1 replied to ststephen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave someone who has some of those skills to help you or show you how. You can just replace boot if you haven't lost all the grease which is spattered around the underside. You will need a breaker bar to remove nut visible with hubcap off. Also a steering linkage puller is a great help so you don't mess up threads "beating" it out with a hammer. It's not a job with only a screwer and pliers! $200 fo parts and labor isn't that bad. A rebuilt shaft cost about $100 "I'm guessing" and can be found on internet or the chain part store. There should be good Subaru guys in Co.
95 2.2L block coolant drains?
I replacing the coolant and would like to get all old stuff out as it's about 3 years old. Is it those large flush plugs with the hex opening? As I remember they were slightly different diameters. If it is they are sure much easier to get at than the 1.8 OHC's. Off topic of my post, I used a Subaru timing belt and had marks on belt with number of teeth between sides and crankshaft. Really handy for this shadetree mech. Do the other parts houses do that too?
95 2.2L timing belt tensioner plunger
roger1 replied to roger1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't think would have done any damage, as I suspected something was going on and decided to go here and work in morning. I don't think it moved .030. My Haynes didn't give any hints like that! Thanks for the heads up!!!
96 subaru legacy mods
roger1 replied to comixjunky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's located passenger side,toward intake manifold just beyond the air filter housing. It's has several wires in cable running to it. Bigger cable than one would think! Good luck!
I am replacing timing belt and was doing fine until I tried to push plunger in and pin it till I got the pulley installed. I put in a vise and try to push in and cannot believe how much pressure I put on it and didn't appear to move. The plunger rotates in it present position so I assume it 's not "frozen". Any help would be appreciated
Once again - noisy lifters
Lets Hear it for Marvel Mystery Oil!! This engine EA82 sat for a long while and it sounded like a pwr stroke diesel. I used a stethascope so I knew It was on pass sidel It was idling about 1000 rpm's and I added about a pint to crankcase. Five minutes later it sounded like a Subaru. I've heard about AT fluid but this was on my shelf so I tried it and it worked!!!!
Stereo wiring 86 GL-10
Some nice thief cut the wiring harness of stereo taking plug of stereo unit and mating connector. I have a another radio with a plug and another female connector to splice on to main harness. In reviewing the colors they don't match to wires on harness. If I have the colors that mate I can have a direction to go. Can someone help me out as I can rearrange them to work ( Ihope !)
Cold start only
My 86 turbo gl-10 starts when cooled off (2hrs in 80 degrees) If I shut it off it off and try to start instantly it won't start. I had someone crank it over with timing light and appears normal firing. What would be sensitive to heat that needs to be ambient temp?. I am going to change timing by a tooth as I cannot get it on the marks. Turbo's have a large number (20+ degrees) so is that possibly my problem?
My first Soob
I have a set (4) alloys off a 87 roger1@cybermesa.com
Fuel pump power
Thanks Folks, It was the relay! I had one in my parts cache. I had to work with mitchells and chilton w/d so it took me a while to make sure I was at the right relay because the wire colors weren't exactly. Like rd/bk when it was bk/rd etc. It was a real good learning experience for me as I have a much better understanding of the use of relays.
Fuel pump power
I have a 86 gl-10 turbo . The old fuel pump died so I replaced it and have hooked a 12vdc power supply to pump gas to engine compartment in cup. I know that works! When I turn key and activate starter or leave it (run ) I get no fuel pump be energized. Any fuses with fuel appear to be ok. With fuel line open like there should be no pressuure shut off activated. Does the fuel pump run continuous while cruising down the road? It was working when I parted it 6 months ago. I don't think any varmits have gotten to wiring. I haven't seen the blue and white wire at fuse box. Do they split off some where else? Thanks!
