SUBARU BATTERY SETTLEMENT WEBSITE
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood luck with that... if it gets driven on the roads in the winter, it WILL rust. Insidious stuff... not to dissuade you from coming here, but i would budget in a cheap rump roast winter beater for those snowy months. that would imply you had something worth spraying to begin with.. not something easily come by locally. Importing something rust free is also not easily done when on a very limited income.
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsimilar situation here in WI - not a lot from the 80s, or before, survives here, and the ones that are still around have collector plates on them and only get driven in the summer months. Heck, not a lot from the 90s still on the road around here.
2008 OB ticking until warmed up
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it is anything like my 02 Forester was, the colder it gets, the worse it will sound, but as ido said, pretty benign, just sounds terrible. in the summer months, mine barely made any noise at all, but in the dead of winter it sounded like it was going to blow any second.. once it was fully warmed up it was as quiet as a church mouse..
Aftermarket rear gate lift support 2008 OB
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXonly ever had to replace one set on a Subaru, and I think i used Strongarm brand. I personally did not have any fitting issues, but it is kind of a pain in the backside job to get done. LOL if they are shot anyway, take one off so you can take it into your local parts store to match it up, paying special attention to the mounting ends. on the subject of RockAuto, i cant say I have ever had a problem with them, either.. other than them not having a specific part i might want, lol, but that has little to do with them in general. some parts are just not easily available.
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi thought they had resolved the piston slap thing by 2008 heck, even my 2004 doesn't slap like the 02 did.. that one sounded like it was going to blow itself apart on a cold start in the winter until it warmed up... and for the record, the 04 has the same engine family as the 02 did - EJ251
Radiator Hose Rock Hard w/ Intermittent Heat 02 Impreza N/A
heartless replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpressure tester would be a good idea and could help you pinpoint any small leaks. and yeah, i am referring to those lines, but one in particular... if you look here: http://opposedforces.com/parts/impreza/us_g11/type_2/cooling_system/water_pipe_1/ the one i am specifically referring to is shown at the bottom of that image, and has a small offshoot that goes to the throttle body (the small hose at the top right is the one that connects to the throttle body).. that junction is often a failure point - have run into this twice over the years, once with a 2.2 Legacy and once with a 2.5 forester... If you follow the hoses from the firewall back to the engine, one will connect to the upper, large aluminum crossover, the other, slightly lower, will connect to the tube in question here. you could have a small leak that is not bad, yet, but will get worse over time - IF this is the source of your problem. a small leak will cook off lost antifreeze fairly quickly, but it will pool more as it gets worse... look for any signs of dampness on the top of the block in the region of that small offshoot line. So yes, checking while running is not a bad idea. that particular pipe is listed with the water pump in the diagrams (for part numbers) - seen here: http://opposedforces.com/parts/impreza/us_g11/type_2/cooling_system/water_pump/ It is also possible that the wrong radiator cap was the primary source of your problem and the system is simply working out air bubbles now (temporary loss of heat).
heartless replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou thoroughly checked the top of the block - on the drivers side? there is a tube that runs from front to back along the drivers side - inboard of the head, but hidden by the intake - that is often a culprit in situations like this... not usually all that obvious unless you have a clue what you are looking for.
Oil change recommendations
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthose two, not so much.. the 5w30 is pretty common tho
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXon pretty much all my older Subes I ran 10w30 in the winter - Yes, it can get damned cold here in WI, too.. -15 to -20F is pretty common through Jan & Feb, and lower than that happens regularly during that same period. Coupled with high winds, yeah.. not fun. ran 10w40 in the summers when heat was a factor... never started running anything else until this most recent Forester that specs 5w30...
Strange battery & non-cranking problems - please help ??
heartless replied to smallhagrid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake a good hard look at how the old cable is set up.. that will tell you all you need to know.
heartless replied to smallhagrid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably not the terminals, but the cable itself.. best option is to replace the entire cable - that changes the terminals as well
heartless replied to smallhagrid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsince things went from bad to worse with the battery changes, I would also suspect bad cables... every time you changed the battery, the cables were moved, making any weak connections worse.
heartless replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoil brand does not make that much difference these days... I use cheap oil (Fleet Farm brand - regional chain) but good filters.. Wix or Purolator - Fram filters are garbage. obviously, a synthetic would be better (even in an off brand), but if you are changing frequently or it is using oil, then it is more costly as well.. my old 2002 Forester had 285K on it when I sold it, and was still going strong.. fwiw, i also used the slightly larger Legacy filter (Purolator # 14460. Wix # 51334) fits perfectly, no leaks, no issues.
215/65/17 2008 Outback
heartless replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlol, already gave him that site (first reply)
heartless replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi am betting they would fit fine.. might have a tiny bit of rubbing at steering lock, but minimal.
heartless replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey might fit the car... will definitely fit the wheels.. the sticking point is going to be clearance on the front strut spring perches. like i said, punch the numbers into the tire comparison tool.. check the overall height - narrower width to the bigger side wall ratio.. 65% of 215 vs 60% of 225 wouldnt think there would be that much of a difference in overall height - but use the tool to make sure.
heartless replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo here: https://tiresize.com/calculator/ Input the stock size on top, and the size you want to mount on bottom it will tell you size difference, what affect it will have on your speedometer, etc.. without knowing what your current/stock tire size is, cant really say much about the snow tires, altho.. a 215/65 is not really a good aspect ratio for snows - in general... i would be looking for a taller side wall (the 65) to be honest - 70 or 75... just my 0.02 cents
99 2.2 possible HG leak 213K
heartless replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhopefully not with FedEx again, LOL
heartless replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow... that is totally not acceptable. Friggin FedEx.. i hate having to get stuff through them.. they have really gone downhill
80ohms on primary coil pins?
heartless replied to joomanburning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvalid... and because of the failed readings across the specified terminals, it does suggest the coil needs replacing. personally, i would try going the used route before i would spend the money on an aftermarket unit... they dont fail so often that a used one would not be worth while... if you have any yards near you with available parts, you could take your meter with you and test on the spot - keeping in mind the +/- 10% range of that 73 ohms... (would be something between 66 & 80 on the correct terminals) Not sure about other compatible years but you may have options there.. as long as the specs are correct and the bolt holes line up.. I put a 1990 coil on a 1995 Legacy.. worked perfectly.
heartless replied to joomanburning's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXum, terminal 3 is not specified in that image... and not having the whole thing in front of me, wondering why you are using terminal 3? terminals 1 & 2 and 2 & 4 should be 73 ohm, +/- 10% (80 would be just within that 10% range) - says nothing about terminal 3... if you arent getting readings on the specified terminals, then yeah, i would swap out the coil pack,
heartless replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdont discount it just yet.. it could very well be just the leaky radiator. It wont suck coolant back in, because the system is not sealed properly - and it could be pushing it out for the same reason. get the new rad installed and see how she behaves before going down the "needs head gaskets/engine replaced" route.
demonic caliper bracket bolts
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXand when all else fails, and you end up rounding off the heads, I can confirm that these do work... https://www.irwin.com/tools/screw-bolt-extractors/5-pc-bolt-grip-base-set but as ido said.. make SURE you are on nice and square..
ignition coil 2008 OB alt to SOA?
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood used would be an appropriate choice here.. car-part.com coils dont fail that often to preclude the used option. and yes, you can have a failure on just one cylinder
08 Outback torque specs
heartless replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot to my knowledge, but I bookmark useful sites like that for my own future reference. I also have the Opposed Forces catalog for parts searching.. and several useful parts websites.
