Bluestone Posted February 23, 2010 Share Posted February 23, 2010 The battery in my 2000 Legacy wagon is loose. I can't figure out how the battery is secured to prevent it from moving around. Does anyone have a diagram or picture showing the battery properly secured which they could post? There's a metal plate across the battery top through which two slim rods, one on either side, pass through with a nut on each end which tightens, and the other ends are hooked. To what are the hooked ends secured? The battery sits on a sort of plastic plate . The plate has a grove in each end. I tried to secure the hooked ends of the rods to the plate but it's not at all secure. When I replaced the spark plugs a while back I did remove the battery for easier access to the plugs but can't recall how I secured the battery after putting it back in. Possibly I left a critical piece out...dunno. Anyway, a diagram or picture would really help. Quote Link to comment Share on other sites More sharing options...
86subaru Posted February 23, 2010 Share Posted February 23, 2010 there should be slots where the end of the rods fit into , tighten the bolts or wing nuts, Quote Link to comment Share on other sites More sharing options...
OB99W Posted February 23, 2010 Share Posted February 23, 2010 [...]To what are the hooked ends secured?[...] There are elongated holes in the sheetmetal below the plastic tray. The hooks go into those holes, and the rods will fall into the "grooves" of the tray. Perhaps you need to back off the nuts so that you can get the hooks to engage the holes. If you shift the tray back a bit (and have enough light) you should be able to easily see the front hole. Quote Link to comment Share on other sites More sharing options...
Bluestone Posted February 23, 2010 Author Share Posted February 23, 2010 Ok, thanks; car's outside, I'll wait till daylight. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 23, 2010 Share Posted February 23, 2010 They are a bit hard to find. Sometimes i have to remove the battery to find the silly things. Quote Link to comment Share on other sites More sharing options...
