My EJ22T swap.......and a few issues
Hey, on a side note, does your ecm have a built in map sensor? Mine does, which I thought would be for a turbo model, but my brother has a turbo 1.8 and a turbo 2.2 and neither one has a map sensor.
Im pretty sure thats not a MAP sensor.
(manifold absolute pressure sensor)
But a BARO sensor.
(barometric pressure sensor)
A map would have to have a vacuum hose coming from the manifold and plugged into the ECU.
I have never seen a stock subaru with a vacuum line, however i have seen them with a hole that looks like a BARO sensor.
  • Replies 104
  • Views 21.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • awesome! looks like a clean swap, love the video....especially the last few seconds   why did you pull the dash, though? yikes!     alright, 1: the set screw probably won't effect the idle that
I dont think mine does, its a 92.
What year is yours, if you know?.
Mine is from a a 94 Legacy Import.
But a BARO sensor.
Thus my confusion, this is a 4 bar map sensor, with vacume line, which i plugged in to the manifold.
Looks great! I have a replacement trans I need to get scrubbed up but you're obviously more qualified to do so than I am.. come on over when you're done!
:grin:
What'd you use, kerosene?
:grin:
Sure, I only charge $20hr and my choice of beer.
I use the purple cleaner you can buy at the auto stores. Then rinse with water and finish off with the wire wheel and a quick spray of clearcoat.
Great work. I really love your attention to detail!!! Too bad you couldn't bring this with you on your next trip to Maine!!!! I would really love to see this car in person!
So should another old fart stop by and give you a hand putting it in tomorrow?
Got the trans installed yesterday, thanks to capn_r for the help.
Need to button things up and then it will be fingers crossed till Aug 20th :rolleyes:
just don't drive it till then. Less risk of blowing something up again:lol:
I dont want to be halfway to Cashmere and have it go out on me :-\
And if something does happen, I will have time to fix it before the Show.
Oh snap....
Noticed this when I was re-installing my trans.
Had a diff core laying around with a good bushing, so it was replaced.
And while I had the diff out replacing that, do you think I stuffed it back up there looking like this?
I messed up and forgot to take after pic :rolleyes:
I'll have to crawl under and take a pic sometime.
Well, after driving it almost a week all I can say is wow....what a difference.
This trans is a lot smoother and since gutting my DP the turbo spools up much quicker and I gained at least 10hp.
You can ask Russ what he thinks of it, he had a good ride in it today ;)
