My '95 Legacy: Trashwagon10
That' s some nice work area you have there! You get to use that garage to work on your Sub? No wonder it is such a pimp ride.
No, thats just the AT&T garage. I'm not allow to use it, although, I could if I get there late enough (After 10pm) and no one would know.
  • Replies 1.3k
  • Views 206.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • TheLoyale
    TheLoyale
    Trashwagon will be making a return real soon!    I built a car created by MilesFox, only to sell it to him and then to get it back.
  • TheLoyale
    TheLoyale
    Trashwagon10 makes a triumphant return to MilesFox! We rescued the car yesterday from a kid who bought it in need of a car to get him to/from school. The outer bearing cage on the passenger side axle
  • TheLoyale
    TheLoyale
    We are The Subaru Alliance!  ____________
Posted Images
Except for all of us...
What all was involved in the retrofit. I may snag the one off my grandmothers 91.
Lol, "Gimmie that cover Granny!"
All you need to do is trim a spot for the EGR and Vac lines so the cover will seat all the way down. You also need to the two metal brackets that bolt to the intake of course.
:popcorn:
Your wagon auto? I don't think my 5 speed one has EGR.
It should have an EGR I would think. But yes its a 4EAT.
Retrofit first gen EJ22 cover.
:popcorn:
HAH, looks familiarly exactly like mine, even down to the strut top dust covers!! :clap:
And some rubber grommets in the holes in those metal brackets hold the cover on nice and tight... Will get pix of the grommets for you...
Edited by superu
Changed the rear cargo light, with one out of a '98 Outback Limited. Yes there is a difference in style and this one uses a larger bulb which puts out way more light!
My 95 Outback doesn't have a dome light. What did you snag yours off of?
My 95 leggy wagon is 5MT and has no EGR only the auto's have them.
Which dome light? Center or the rear cargo dome? My car originally came with the center dome and a cargo light, I added the Map-light from another Legacy, and then I changed the rear cargo light for one from a '98 Outback, due to its a different style.
I wonder why only the Autos have an EGR? :confused:
I bet no one can guess which Subaru these Headrests are out of. (Hint) its an EJ chassis.
where did you tap in for the map light???
that would make my day seriously if I could have a map light lol
and the auto's have a EGR because it's something emissions related.. I don't miss it one bit.. I had one stick open on a 98 Forester.
I just ran a wire off from the center lights power (As its a constant 12v) the maplight grounds its self with one of the screws.
I'm kinda surprised the 5spd doesn't have the same emissions crap? WTF. Making it a 5spd isn't gonna change its emissions :rolleyes:
did you have to drop your headliner? mine is starting to sag a bit but man i don't want to have to deal with the hassle of trying to find the map lights...
I might not be able to put one in because of the aftermarket sunroof switch might be in the way
No, you do not remove the headliner. Just map out where the hole is (Look at the car you took it off of) then just cut the hole and the tapped screw holes will be there.
I have a Gray Maplight from a first gen Lego, I will see if it lines up the same. If so, you want it?
Looks like the same material that my uncles 96 L seats are made of.
I vote SVX.
I vote SVX.
Its a soft cloth, but not SVX. C'mon ya'll! :grin:
let me double check in my car first if so I will take it.. just my sunroof switch might be in the way.. I will try and grab a pic tomorrow.
Ok sounds good.
Well, no other guesses to what these headrests are from? I will answer it now, They are from a Silver 2000 Forester Limited! That is the only Forester with this style of headrest, the XT6 has a similar style.
hmmm never seen headrests like that from a forester...
Yeah, me either.
