W series Toyota trans adaptors
I am building the 4G63 Mitsubishi narrow block that accepts either the R 150 or the R 151 or the W 55 through W 59 Toyota transmissions,
then I have built the T 5 narrow block 4G63 bellhousing and I gotta fill that in and flow it out.
I will be finishing the Sub next ( without delay) all I gotta do is fill in the required wall thickness and flow it out , then off to casting
I am building the V 6 Mitsubishi 6G72 for the GM auto trans
and I am building the Wide Block G54b Mitsubishi T 56 speed trans,
plus I am building a driveshaft machine and some motor mount designs
and i wanna design a new intake manifold for the 4g63
I have 2 starion conquest to build and a 57 Ford
But I gotta get it done before winter because I have to do all the bookkeeping work for 3 businesses plus personal for my accountants because it takes 6 months to get my tax work done
  • Replies 579
  • Views 190.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • bill hincher
    bill hincher
    wish I could go with you, I was in st petersburg Russia when the wall came down .;o) ( true story) all I can do is keep updating my posts and you can watch me here
  • GeneralDisorder
    GeneralDisorder
    Count me in for a B.H..... Just bought a t-cased hatch (THE t-cased hatch?!?) and it's pretty much a no-brainer to go over to the Yota transmission.   Any way we can get on a list for one of the fi
This will be compatible with 02-03 wrx right? If so put me on the list!
this would work with any ej motor and then some.
but keep in mind this is no bolt in kit. this is going to just be a way to hook your ej motor to a toyota tranny, the rest will be up to you.
  • 2 weeks later...
finally, back to the Sub, the first thing I have to do is allow for shrink while casting, the number given is always 1% shrink when casted, but experience says to allow a little more then that
after the inside of the housing is spaced out, then each of the bolt bosses must be spaced out to get a center when machining the housing
you can see here by the outline how far the starter pocet will move at about 2% casting
I like to use a 1 in diameter bolt boss so I have a lot of material for the bellhousing bolts to grip
then each bolt boss needs to be built with about a 3% taper so the pattern will draft
then all the bolt bosses are welded in place
I will finish this project this week, then have it sent to casting next week
best news i have heard all day. :)
i'm sure i speak for many people when i say, i really want to thank you again for taking on this project.
+1
I trimmed out the outer ridge on the existing housing so I could build in the draft line for casting
then I filled in the last two panels in the housing
Then I cut strips of aluminum and welded them on the interior side of the housing, its a way to control the wall thickness, I can be a little off with it on the thick side but it will not be thinner then this thickness through out
then I added an outer trim ring, this will give me a datum line to fill the outer wall to size, you can never have enough clamps when welding >;o)
:slobber::slobber::slobber::slobber::slobber:
oh crap i just drooled on my keyboard. :grin:
Edited by mellow65
We both know that wasn't drool matt.:lol:
i have been following this for a while...
looks like one of the mostest awesomest things ever...
i will have to look into getting one for a new car project...
hope to see a final product with a price tag soon...
i too would like a price and date of availiability, ill probably pick one up
Thinking I just found what the Wife is getting me for Christmas.
Now, just to convince her of that idea.....
look into getting one for a project? hell, i'm creating a project just for this thing. :grin:
i will have to look into getting one for a "new" car project...
thats what im saying hince the "new car project"
nice, :banana:
everyone likes new projects.
funny to base a car around a bell housing that isn't made yet, but i know at least me and monstaru have stuff sitting in the garage waiting ever so calmly, sitting on our hands trying not to get to excited with each and every picture that he posts up. :grin:
Ive been waiting on this to start my new project too. I WAS planning on trading my 02 wrx in for something with better mpg, but since it's paid off...Hell, why not make it rwd?!!!!! :banana:
nice, :banana:
it almost makes me want to puke i am so excited.........
now its just time for a lot of filling and sanding, and filling and sanding and sanding and filling:banana:
careful the new pics, you're going to have to chew it back if you look at them :grin:
