vagen Posted July 14, 2010 Share Posted July 14, 2010 in an effort to gain overall track width I am looking for some 1/2" wheel spacers but I don't know where to start. Any one have any ideas? Quote Link to comment Share on other sites More sharing options...
renob123 Posted July 15, 2010 Share Posted July 15, 2010 in an effort to gain overall track width I am looking for some 1/2" wheel spacers but I don't know where to start. Any one have any ideas? Hmm. I have some spacers for a 6-lug setup. I found them at the junkyard. Here's what I think, since you haven't had any responses yet: 1) All you need are some round pieces of metal about the same size/shape as your hub. 2) 1/2" may be a pain to drill through, so you may want to work with 1/4" or something and just make 4. Maybe not, but it's an idea. 3) I'd do it the same as the 6-lug hub drilling trick. Drill a hole in your round piece of metal. Pound out 3 of the 4 studs out of a brake drum. Bolt the metal to the drum and line it up. Drill through the 3 holes of the drum where the studs were. There are probably smarter ways of doing it, but that's how I would do it. Good luck. Jacob Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted July 15, 2010 Share Posted July 15, 2010 Just turn your wheels around and mount them backwards (Rear of rim facing outwards) That'll give you some extra width for sure Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted July 15, 2010 Share Posted July 15, 2010 just buy some 6 lug wheel spacers bolt those to the hub and drill the 2 new holes in the spacer like you would when modifying a 6 lug wheel to 4 x 140 Quote Link to comment Share on other sites More sharing options...
vagen Posted July 16, 2010 Author Share Posted July 16, 2010 I kind of figured that would be the answer. Quote Link to comment Share on other sites More sharing options...
mountaincarpenter Posted July 16, 2010 Share Posted July 16, 2010 You could get some PUG rims. They have a 1" greater offset.... Quote Link to comment Share on other sites More sharing options...
84gl Posted July 16, 2010 Share Posted July 16, 2010 Have a Machine shop make them all it would take is one six inch peice of bar stock (mild aka 8620,7230 or alum.) bore it to the id of the center of the hub and drill and contersink the 4x140 pattern on the rings you have made (same as making a pipe flange) then drill the bolt pattern of the wheel studs whatever you want it to be 5x100,4x100,chevy 6 lug any pattern that will fit inside the 6 inch od Quote Link to comment Share on other sites More sharing options...
