99 subaru legacy clutch replacment
Welcome.
Search is your friend.
Often discussed.
Some drop the tranny.
I ALWAYS drop the engine. I think it's simpler and usually do all the other major maintenance at the same time. HG's, crank and cam seals, reseal baffle plate, etc.
There was a thread here yesterday/today about someone doing this exact job on a 99.
If you search and read you'll see what most folks do.
I happen to ge thte new clips from the dealer and a Valeo kit with only japanese and american parts.. I always get the pressure plate resurfaced - but that's me. ALWAYS reseal the baffle plate given the opportunity. Stay away from the rear main seal (don't replace it).
My opinions.
Search, read, develop your own opinions.
Folks here are willing to share. They do prefer that a little research has been done before hand.
Ya just depends on what you prefer. I personally take the engine out as well to do the oil seals and such on it. If the engine is in good shape, no leaks fresh timing belt and such, then the transmission removal may be easier. Just depends what tools you have too.
Back when I had a garage I could use I had an engine hoist, but no tranny jack, so going out the top was easier. If you have a tranny jack and no hoist... well going out the bottom may be easier.
Ok thanks again guys for the help
Another question I have is this:
The Legacy is my brothers and we are both going to do the work on it at my garage at my place. So we need to know if there is any of you that might have swapped a 2.2 over to a 2.5 He has a fresh 2.5 out of another subaru
What we needed to know is if this will work without a major investment in mods.
Thanks again guys:banana:
If you have and engine hoist, then I throw my lot in with the "pull engine" crowd. I've done it both ways, and pulling the engine was by far the more pleasent experience. There may be more bolts you have to put a wrench on, but everything just unbolts from the engine and swings out of the way. You don't have to disconnect the power steering system or AC system so it's really not a big deal.
And as Davebugs mentioned, it's the perfect opportunity for a lot of other routine stuff since you'll have easy access.
Don't forget to clean and regrease the clutch fork pivot ball.
One other note, I'd recommend breaking the harmonic ballancer bolt loose before you pull it. I've been using the "starter motor method" which has been working for me, but there are lots of ways to do it. Anyway, the point is that unless you have an engine stand or some other means of holding the motor stationary once it's out of the car, it can be a real bear to get bolt loose.
Good luck!
Will-
It's interesting to note - just about the only modern car I've worked on where it's easier to pull the engine for a clutch job (because pulling the engine is so easy) is a Subaru. Honda's, Toyota's, VW's, etc - generally easier to drop the transmission since there's so little clearance to try and get the engine free in a transverse application.
Usually easier to do the transmission on American stuff too - since even the RWD's have heavy engines and most of those being trucks (or vans :dead:) have the clearance underneath and are difficult to wrangle the engine out of.
Is it any wonder that I swear a lot when working on anything but a Subaru?
I forgot to mention that I have a car lift and a engine hoist to use. With all the tool I need. What I dont know is the difference betweent these two motors
2.2 over to a 2.5
Again if you search around here - or just pay attention to posts you'll see that the 2.5 isn't as sturdy as the 2.2.
Yes if you do the head gasket in time before the rod bearings are effected by getting overheated, and often need to ignore harmless but somewhat noisy piston slap the 2.5 is good. Mind you it's not really that the 2.5's are bad, and really most of their issues are HG related - or atleast start w/HG issues, but the 2.2 is somewhat bullet proof.
BTW I have a lift, engine hoist, tranny jack, etc. and still as stated always pull the engine to look it over, reseal it, etc.
Easy:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202183868&langId=-1&catalogId=10053&ci_sku=202183868&ci_src=14110944&cm_mmc=shopping-_-googlebase-_-D25X-_-202183868&locStoreNum=4018&marketID=54
http://www.sears.com/shc/s/p_10153_12605_00944996000P?vName=Tool%20Catalog&cName=Mechanic'sTools&sName=Drive%20Tools%20&%20Ratchets&sid=IDx20070921x00003a&ci_src=14110944&ci_sku=00944996000P
http://www.google.com/products/catalog?q=22mm+impact+socket&cid=2140107396625314653&ei=8K2WTN7vLpi4iwTI672fCw&sa=title&ved=0CAcQ8wIwADgA#p
Takes about half a dozen good solid blows generally. Pull radiator, slip socket and ratchet over the crank bolt, smack toward the end of the ratchet - reset the posistion of the ratchet and repeat till the bolt spins free.
It's just like using an impact but no air supply and works with the engine in the car (or out). This is how it's done at the junk yard. Works every time.
Incidentally, this method works for alternator pulley bolts, cam pulley bolts.... etc. Just about anything that spins and can't be easily held or stopped from rotating.
