February 26, 200422 yr Ok - so I checked on how my mounts were holding up that I made. As shown in this post: http://www.ultimatesubaru.org/usmb/forum/showthread.php?s=&threadid=10424&highlight=DIY They have melted due to the exhaust temperatures - apparently the stuff I used which was reccomended on a honda site that I found was not capable of withstanding Subaru punishment. So I've formulated a new plan of action. I talked to a local plastics supply house, and they reccomended a place online where I would be able to buy something more in-line with the requirements I have. I have selected this product: http://www.smooth-on.com/urethanes.asp#780 It shouldn't melt this time at least, since one of the steps to proper cureing of the product is to heat it to 150 degrees for several hours before use. Apparently this improves it's characteristics.... For those of you who are waiting on mounts from me, there will be a slight delay while I get this new product in, and test it on my wagon. If this works out, then they also have a clear version of this product that can be tinted any color you want! Kinda cool. I will update all my old posts with links to this one, and to reflect that the older method did not work..... pictures and a test report will be on the way as soon as I get this new stuff, and the mounts have properly cured. GD
February 26, 200422 yr Originally posted by GeneralDisorder since one of the steps to proper cureing of the product is to heat it to 150 degrees for several hours before use. Apparently this improves it's characteristics.... Me talking to Wife: "Hey hunny... mind if I borrow the toaster oven for a few hours? For what? Um..."
February 26, 200422 yr Author It took Edison more one try, thanks for the effort. Thanks for the support! If someone doesn't start making these, we'll all end up paying the $55 each for new ones to SOA. And I would rather have urethane mounts..... GD
February 26, 200422 yr since this new stuff you have to oven cure may i suggest that you make a jig to center the pieces inside the mount then burn all the left over rubber off in a nice fire so its a pure urethane mount i would think a few small pieces of aluminum c-clamped over the open area's would work well for keeping the urethane inside the mount as it cures oh as far as a oven goes just a thought.. go to a second hand store or even a kmart or wahtever mark you have and purchase a cheap toaster oven you can use it also for heating up wheel bearings so they slide over stubborn axle shafts easier ect ect many other uses for a small oven in the garage /end of incoherent rant
February 27, 200422 yr That's odd. The stuff I used (3m windsheild stuff) Is holding up just fine. No meltation or any other breakdown.
February 27, 200422 yr Author Just out of curiosity, how long did you let them cure before installing them? Maybe I didn't let them cure long enough or something. I waited overnight, and they seemed well cured to me.... GD
February 27, 200422 yr Author I haven't made any engine mounts yet - but I certainly could. The engine mounts are almost always still good in my experience, so there hasn't been much talk of those yet. Also - urethane will increase vibration at idle more with urethane engine mounts than it does for just the small tranny mounts..... GD
February 28, 200422 yr Author It might, but I would tend to think the urethane too soft for bushings. They do make other types of plastics that would do the job tho. Something with the properties of nylon would work I should think. Are you talking about 4 speed bushings or 5 speed bushings? GD
February 29, 200422 yr Sorry about the delay before reply. I let them set for about 24 hours before using them much (besides moving the car out of the alley after about 8 hrs). Can't remember exactly when I did it (think it was Sept), but I triple-checked them after reading your post, and they are definitely OK. The 3M is designed for a 24 hour cure, so that could be it.
