January 7, 201115 yr what you anyone recommend i use to get the carbon buildup off my intake valves? there's a ton of it on the intake valves on both heads.
January 7, 201115 yr If its in the car, use a small vacuum line to suck in some seafoam, slowly, should take between 8-15 minutes to suck in the whole bottle. Out of the car, soak em in carb cleaner and use an aluminum or brass brush.
January 7, 201115 yr I use a brass wire wheel in a drill chuck to clean the cc's and valves when the heads are on the bench.
January 9, 201115 yr I use a brass wire wheel in a drill chuck to clean the cc's and valves when the heads are on the bench. What he said.
January 19, 201115 yr If its in the car, use a small vacuum line to suck in some seafoam, slowly, should take between 8-15 minutes to suck in the whole bottle. Out of the car, soak em in carb cleaner and use an aluminum or brass brush. ding ding ding!we have a winner!in the car nothin better than seafoam. Edited January 19, 201115 yr by monstaru
