Starting problems '84 Gl
mkoch
Symptoms:
About 30% of the time while cranking the engine, the engine will turn slightly, then stop (as if the battery is not providing enough current). After I repeat this process about six times, the engine will turn over and start.
About 70% of the time, the engine will start on the first try, no problem.
The battery test at Autozone indicates that the battery is good. I also run that battery in another car, with no problems.
I'd like to solve this. Where to start?
