So I saw this on CL
its a 1999 outback
Our mechanic said it needed new head gaskets it has 200k miles on it.
So we paid a small fortune to have them replaced,
Along with the timing belts and dampener pulleys.
It ran great for a month or so and died on us.
I am not a mechanic Looks like one of the pulleys came off and it spun the new timing
Belt.
So I know this is pure speculation, but what else could have gone wrong...bent valves? Is it worth repairing or just replace with ej22? He is asking 2k for it. I have a picture but can't seem to upload it.
Edited by cohophysh
Odds are very good of valve damage.
At 200k it's probably getting a little tired anyways.
If a pulley truely came loose I'd suggest a different independent shop.
If a pulley failed please post the brand and where purchased if possible.
Dampner pulley confuses me. There is a crank pulley/harmonic dampner pulley - it's the big one on the end of the crankshaft. That is different from the idler pulleys that are run by the timing belt.
We need more information.
If the harmonic dampener pulley came loose they don't know Subaru's - we're back to finding a member or an independent shop that knows Subaru's.
At this point with these issues and that many miles I'd probably suggest (at the expense of folks complaining lately) to do the 2.2 swap. Lots of information here on fixing the 2.5 or swapping in the 2.2.
A few suggestions.
Are you nuts?
An 'R' title, 200k and needs an engine. For 2k?
Outbacks must be worth more out there but if you can't do the work yourself you're probably better off taking a pass on this one.
A 2.2 would be the answer rather than tryin gto figure out what is messed up with this one. And that's probably gonna run you 1k or so.
Now you're over 3k into an 'R' car with over 200k and you get to find out what ELSE is wrong with it. Things like torque bind, rod knock and such.
Folks here will do their best to help. But I'm thinking you outta pass if you can't 2.2 it yourself. And even then it's questionable.
That's a bad investment. $2k is WAY too high. More like $1k. I would buy it for 1k, do a 2.2 swap and sell it for $5k (and I would get it).
180k is my cutoff that I've found. Beyond that folks around here won't pay much.
But I'd do the exact same thing - if it were local and under 180k.
"Rebuilt Title. I have the title.
Was a small fender bender when it was brand new"
Here's what I thought. I don't believe "a small fender bender" recieves a "Rebuilt Title". Isn't an R title the same as "Totaled"?.
"The bad.
I recently relocated several hundred miles, and
I don’t have the cash to throw at it again so I am selling it."
I think there is a good chance he's settled with the mechanic. You don't pay "a small fortune" to a shade tree mechanic.
"Put the motor back together and drive it for another 200k.":lol:
Or not.
Doug
