My 1993 Loyale: Work In Progress
So I'm finally the proud owner of a Subaru again!!! :banana:
Roughly 175k on the ticker.. runs like a beauty. Just needs some definite TLC.. maybe a beating or two :lol: I was inspired... or was it forced? I'm not sure :-p to create a thread about my repairs to my new baby. Beginning to end. If there is an end! :rolleyes:
So here she is in all her glory. :)
  • Replies 263
  • Views 45.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • 92_rugby_subie
    92_rugby_subie
    sounds like a hazard I think I will keep my car on the road and keep my fuel pump where it belongs.
  • urethane, not silicone
So when I first went to get her... we couldnt get the car to start :confused: No fuel was getting to the fuel filter, so we dolly'd her home. When I got her home she still wouldnt start. Didnt hear the pump running so I checked the fuse, it was fine, tried to find a relay, not sure if I did or not. lol. But I unplugged and replugged in a few things under the passenger side dash, then crawled under the car to find the pump itself. I unbolted the shelf it was on, I thought maybe I could hear it better that way (I didn't have anyone to turn the key for me) So I turned the key and smelled gas from the engine bay, :eek: I looked and all the sudden it was working, gas was getting to the filter! I
rehooked everything up and she started right up! So I'm not sure why.... any ideas? I don't think I did anything special! Lol.
WOOF.
Thats gonna take some work...
You need to do some body work, paint it and put some black pug alloys on it.
EJ swap etc.
At least youre Fuel Injected...
I need to do a Fuel Injection swap, but Ill do that with the EJ swap lol.
Are Loyales pretty common in your parts? be able to get the body parts?
Finally you make a thread about this! I have been waiting for this.
I hope this will be an on-going thread like both of mine were! :banana:
Wow!
Looks like you have quite the project ahead of you, although it's in better shape then most of the old subis I have started with :grin:
Any ideas on why all the sudden fuel started getting to the filter? One thing I forgot to mention before is that the car had sat for over a year... which I'm supposing contributed. :) Thx
When you moved the fuel pump from under the car it might have caused the wiring to get better contact. I've had this happen before with a bad ground.
Could have gunk in the fuel line and the pressure from the pump pushed it out.
If i'm trying to start a loyale that hasn't ran in a while, and it wont start, I rap on the underside of the fuel pump tray with a small hammer or something. About half the time the pump starts working and works fine afterwards. So, it's not uncommon for them to "stick" after sitting. Or, like Rob said, maybe a ground wire problem which will eventually show up again.
Wow that looks like a cool project! Do you know what happened to the car? How much did it cost?
I've got a hood and fender (light blue) if you can't find them closer. I'm about 100 miles from you.
Word to the wise, when you do a tune up. Make sure you run NGK BPR6ES-11s and NGK Wires. Your Subaru will Thank you for it.
Re-he-he-heeaallly? :brow: Collville aint too far away... :D PM pending. :banana:
And the car was 200 from a friend. Quite the deal. He needed it gone, I needed a car! His sister rear ended a truck. effed up the hood, fender, lights, etc. He used the other light on another car... it sat for a year when he decided to get rid of it. Perfect timing!
Tom you butthead! You're on usmb but not yahoo?? :-p
Must not be skilled at multitasking, tsk tsk
Lets see... What am I doing:
Facebook
Craigslist
MSN
Yahoo
Yahoo Mail
USMB
Texting
XBOX 360
Im awesome :P
I am not on Yahoo cause I need a break from talking to you all night! Plus I'm not in a completely talkitive mood ATM.
WIX or Genuine Filters, NEVER EVER use a Fram. That will be the death of most any vehicle. ;)
Lol! I know sorry :-p I shouldn't keep you up so late! Plus I have school in the morning... Hopefully I'll have time to run to the junkyard after school tomorrow or wednesday!
Just remember, I AM always here for you.
I don't have really any extra EA82 parts which sucks. Just slap some Legacy headlights in there, little bondo work and they will be "Custom" :lol:
So I was busy showing my car off to my uncle, I started it up... every time I do it runs around 2200rpm until I kick it down to around 1500. Well after a few seconds it knocked itself down to like 1000 and the lifter knock got really quiet. I'm not complaining it just seemed really weird that it did that so quickly...
If the motor is cold, the IAC is gonna hold the engine at a higher RPM until the engine gets heat, thats what its meant to do. You can kick it down as you did by taping the pedel, but it'll climb back up a little bit.
1000rpm is normal for the EA82 if you've only been letting it idle.
Yeah but that's the thing.. I've never had it idle this low and it only did it a few seconds after I started it up, it hadn't been running long enough to be at running temp. idk. just struck me as odd...
Well, you could dump some Seafoam down the IAC, maybe its a little dirty.
My EA82 will drop down in idle pretty quick if you jab the throttle.
Mine does that too
Embarassing as all hell to try and start out super quick against a honda and hit the throttle hard and kill the car :rolleyes: but I caught up lol
I think tomorrow I'm gonna go do a general tuneup. I've yet to check the plugs/wires/oil/etc. And I need to use up my can of seafoam. Anything else I should check out?
