Driving me nuts
Just replaced timing belts on my 89 GL EA82 followed the link on here, turn crank till 3 marks one cam up turn crank 180 other cam up turn till timing marks install dist adjust to 20deg
idles perfect but backfires and now power driving
Please Help:eek:
Edited by pepsiguy
wasn't my first thought but i bet Qman has your demon covered, so start there.
you pulled the distributor? if so, double, triple...more...check the alignment, they're easy to mess up and seem unclear sometimes.
i think you mean 360, which is what it should be, or i'm reading it wrong.
1,3,4,2
And yes 360 deg not 180
could the crank be off 180?
Edited by pepsiguy
added content and spelling
Did you mean you turned the CAM 180? If you only turn the crank 180...actually, I have no idea what would happen. Turn the CRANK 360, which will spin the first cam (assuming it started with the mark pointing up/lined up with the valve cover seam/timing belt cover notch) so it is pointing down, 180 degrees from where it was.
I just did this. When I put the belt over the tensioner it pulled the cam to the left one tooth. My bro said it was right, It wasnt. I ended up getting it right on the 3rd shot.
Make sure thy line up exactly, I looked through the hole in the cam pully and centered the valve cover gasket in it.
now all im waiting on is a petcock for my rad.
good luck
1,3,4,2
1-3-2-4 is correct order.
rechecked cam gears
Flywheel at three marks
left is at 12 oclock in line with the grove in the cover
Right is at 6 oclock position
turn flywheel 360 deg to three marks Again
now left at 6 oclock
and right is at 12 oclock
firing order was set 1,3,2,4
is it possible the valve lash is way off from last person to work on it
has hydraulic valve lash adjusters, doubtful anyone ever messed with it and doubtful that's the lone cause of it not starting.
Did you plug the green test connectors when you set the timing?
Timing set with fining light to 20 deg with green conectors connected
Like I said idles perfect but no power and backfires under load
Yes I did unplug green after setting timing
And no codes what so ever
  • 2 weeks later...
:banana:figured out the problem by accident :banana:
unplugged map sensor and prob solved just needed to clean it now car is perfect
thanks everyone for all the input
