Timin' Belt Covers.
Once the Lifters were Ready, I had to ask to a local friend who has a small repair shop,
his kind help and letting me to pull the engine in its place with his tools...
  • Replies 81
  • Views 17.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • idosubaru
    idosubaru
    jesek - you're so talented just press in new bearings into the timing pulleys and all you need is belts and tensioner springs if you want to replace those.
  • Loyale 2.7 Turbo
    Loyale 2.7 Turbo
    Well, the time challenge has been met, successfully! Almost three decades and a half of continous ownership of my Subie, all of them running with this carbureted EA82 which is the original engine
  • Good to see you are still lurking this forum Jes. Still got the blue ink in your pen
Changed all eight old worn Hydraulic Lifters with a set of brand New ones, with their oil filler holes already aggrandized. Changed the old worn valve covers' Seals. Changed both Timing Belts.
Changed the worn old Pilot Bearing from the Clutch...
Here is a short video, from the Test after all this were done:
(featuring weird background music to avoid copyright issues and laugh a little)
Awesome!
I subscribed to your channel.
The EA82 in the BumbleBeast still sounds very healthy.
  • 1 year later...
On 8/6/2022 at 8:16 PM, 6 Star said:
Awesome!
Thank You! ... it still is running Strong and smooth at the same time, no noisy lifters anymore,
at least for this more than a year since the modified lifters were installed. :)
Kind Regards.
