Lukas Posted August 8, 2012 Author Share Posted August 8, 2012 It was 4-lug from the factory, like every Leone. The 5-lug-conversion was done by the previous owner, but as I wanted my very rare pre-facelift-Turismo original, it was biult back to original condition. L Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 10, 2012 Share Posted August 10, 2012 ... That´s a lot better! Isn´t it beautiful? ... Yes, it Does Look very Beautiful, Good Job! I almost can't wait to see the Final results. Also I Like the Mahindra Pick up in the Back, we have many of those in my Country... the "Scorpio" Diesel is pretty Popular. Could I Ask if you plan to use the Steel 4X140 subaru Rims, or do you plan to put a set of alloy 4X140 rims? Kind Regards. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 10, 2012 Share Posted August 10, 2012 as I wanted my very rare pre-facelift-Turismo original, it was biult back to original condition. L if u want it back to original condition wouldn't it have the gl-10 motor(ea82t) in it with the factory front and rear disc brakes but its your project(i plan on putting a ee diesil in my 85 brat someday with a 6 inch lift kit and running 15 in peugeots:headbang: it has a totaled title soo... that just means im going to have another brat close to stock;)) Quote Link to comment Share on other sites More sharing options...
Lukas Posted August 10, 2012 Author Share Posted August 10, 2012 No, it had the EA82 with carb as standard. The only thing that will not be like when it came from the factory is the gearbox with AWD, low-range and lockable center-diff. It had the push-button-4WD standard. @ Loyale 2.7 Turbo: A friend of mine imports Tata Xenon and Mahindra Pick-Ups to Austria. Only in small numbers as workhorses for communities mostly. They are called Mahindra Goa here because Ford did not allow to call it Scorpio like their model from the 80s and 90s. I´m not sure about the wheels. I may put some original alloy wheels on, but I have 4 brand-new steel-ones too. Let´s wait and see. L Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 10, 2012 Share Posted August 10, 2012 good thing u put the ea82 in it because here in the USA the ea82t doesn't have the heads made for it anymore which means your prity much screwed if u cant find a used one or a parts car Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 10, 2012 Share Posted August 10, 2012 If you happen to come across another set of tailights in mint shape, I would be highly interested! Quote Link to comment Share on other sites More sharing options...
Lukas Posted August 14, 2012 Author Share Posted August 14, 2012 I will. I wanted the carbed EA82 in it because that´s an engine which will always run, here it has the reputation that you can´t kill it. No electronics, no Turbo, just a simple carb. It will always be repairable. That was the intention. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 14, 2012 Share Posted August 14, 2012 yep there great motors saw one that went up to 650,000 miles without rebuild thats why it ended up in a junkyard, if u take care of these cars they seriously last forever (as long as u get rid of rust:brow:) by any chance is there any 85 brat tail lights over there? i thought there might be more of a aftermarket selection over where u live because there isn't much left in the US Quote Link to comment Share on other sites More sharing options...
Lukas Posted August 16, 2012 Author Share Posted August 16, 2012 Forget it, sorry! The Brat-Pickup was sold in very small numbers here and there are two surviving examples left in Austria, so sadly no parts and no cars. It was available from 82 to 84 here. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 16, 2012 Share Posted August 16, 2012 thought was going to be the answer but doesn't matter anymore picked up a set of tail lights, the third(passing lamp, scyclopes, ect.), third eye grill, head light bezals for only $150:banana: 15 minutes from my house:cool: Quote Link to comment Share on other sites More sharing options...
Lukas Posted December 29, 2012 Author Share Posted December 29, 2012 Another little update from my Leone. Finally, every rust-spot (we discovered another small hole in the passenger-footwell) is welded, the whole car is at least 5kg heavier because we flooded every panel, the sills and the complete underside with waxoyl so rust will never get this Leone anymore! Now my friend and mechanic has started to get the car back together. He starts at the trunk and works forward. Some pictures from my visit to the workshop yesterday. Let´s wait and see what problems will occur on it´s way back together and on the road. Lukas Quote Link to comment Share on other sites More sharing options...
Lukas Posted April 25, 2014 Author Share Posted April 25, 2014 Remember this one? Last tuesday, it got finished! Look at the beauty of my 1986 Subaru Leone Turismo 1.8 GL Full-Time-AWD Dual Range: Runs great, looks great, sounds great. One of the best Leones in Austria! Lukas 2 Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted April 25, 2014 Share Posted April 25, 2014 Looks top notch, Lukas. Congratulations! Quote Link to comment Share on other sites More sharing options...
TallonX Posted April 26, 2014 Share Posted April 26, 2014 That's just beautiful... Quote Link to comment Share on other sites More sharing options...
Lukas Posted May 5, 2014 Author Share Posted May 5, 2014 Last weekend, I took part in a classic hillclimb-event. We had to drive up a hill two times, they took our time and the driver with the most equal times won. I was 19th from 21. Yes, I was 45 seconds faster in the second turn. Just because I had so much fun in the Leone. 1 Quote Link to comment Share on other sites More sharing options...
lastchance Posted May 5, 2014 Share Posted May 5, 2014 Welche Stadt in Österreich leben Sie? Quote Link to comment Share on other sites More sharing options...
wagonist Posted May 6, 2014 Share Posted May 6, 2014 In Europe, we got the same rear-lights as the JDM-versions, so they are pretty standard and normal here. Yes, that´s a fog-light on the left, rear-view-light on the right. Actually, no you didn't. JDM doesn't have rear fogs, so are the same as USDM & ADM. It was the same with my 93 JDM Legacy import wagon. It had larger red part, "clear" indicators & then 2 reverse lights. ADM got yellow indicators with 1 reverse light & 1 rear fog. Quote Link to comment Share on other sites More sharing options...
wagonist Posted May 6, 2014 Share Posted May 6, 2014 Actually, I'm a little surprised no one from the US had a whinge that you "wrecked" a high roof wagon to help with this project Seeing as they are rare there. It's the same as us Aussies complaining when a US person wrecks a coupe Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 6, 2014 Share Posted May 6, 2014 Coupe is looking good. It must be super fun to drive around and just cruse with. Quote Link to comment Share on other sites More sharing options...
