March 2, 201214 yr What is wrong with this motor? Nothing? Besides missing a few things. Mr. Adventure, how come you don't buy this motor? Vs the EJ18.
March 2, 201214 yr PM sent. Got the EJ18 anyway. (Just in case) Cool. If I remember right, you could take the heads from an EJ22 and stick then on the EJ18, for a High-compression EJ18 (Or some such thing) Useless information, but figured I would post it
March 3, 201214 yr Pretty sure the 18 heads have smaller valves and the combustion chamber is the same size as the 22. So you get the same compression and less air flow. Something along those lines anyway.
March 3, 201214 yr too bad your not down here in tx. i have a ej22 block with 205k on it. doesn't smoke, and ran dang good until I blew a HG on it, and never over heated it, just kept it full of water. It was in my 5 spd 90 lego. I dropped in a junkyard ej22 with 150k. I would give you that block for $50 and help you do the head swap for beer! I am thinking about tossing my left over ej25 heads on it for a boost in flow, and drop in compression ratio and turboing it... hmmm decisions decisions
March 20, 201214 yr Author Picked up the motor. Swapped out a bunch of parts. Swapped over the timing belt, water pump, fuel injectors, evap canister, air bypass valve, and any hoses that looked newer. Got everything installed. Looks pretty. Pics soon to come. But when I start the car it either A - sputters and dies. I can keep it going for a bit by giving some gas. Or B - Revs WAAAAY high. B is most common. I have to turn the car off about as quickly as it starts. I have checked and rechecked all vac lines and wiring. No leaks anywhere that I can see. Thoughts on what could be causing this?
March 21, 201214 yr Probably not your problem, but my Legacy was revving high the other day. I looked everything over...then I realized it was the cruise control cable stuck. Worth a look. Good luck.
March 21, 201214 yr Author Been researching and so far my best guess is the Idle Air Control Valve. When I swapped it over, I used RTV instead of a gasket. I'm thinking if some of it smushed into the valve and blocked the air passage, it will read low and possibly send the wrong signals - hence the revving. If not that, a few sites suggest that it could be something stuck in the throttle body. I'll check and see after work.
March 22, 201214 yr glad to hear it at least fired off for you. yeah, i would be looking at the IAC valve too...also make sure the throttle cables are seated properly & not getting hung up. hopefully it is something simple and she will be purring like a kitten soon.
April 21, 201214 yr Author Waited long enough to post up pics. Now that she's moving, I've been posting less. here's a few snapshots of the process. Old Engine out. Carnage. (More pics of this to come. It's demolished in there. "New" engine going in seated. Had the worst headaches figuring out that I neglected to swap over the o-ring seals for the fuel injectors. I didn't even check to see if there was anything there to be swapped when i swapped the fuel rails over to the new engine. Car would redline right after starting. idles well now. Some more tune up stuff is in order in the not so distant future. But the car runs, drives and rides nice. Very cushy. Very clean. Very smooth.
April 21, 201213 yr I am just glad that you did get it sorted out! I was starting to feel bad about the whole thing..LOL so what exactly happened with the original motor? I can see the hole in the top of the block, but - why?? what caused it?
April 22, 201213 yr One of the rods decided it was time to bust out of the joint! You gonna split that block and take a few pics of the escapee and internal carnage?
April 23, 201213 yr Author That's the plan. Got almost everything useable off the old engine and will be posting up pics of the damaged on as I take the block apart. Surprisingly, it's not seized up entirely. The shaft still rotates 360.
