March 2, 201214 yr Looking to switch to a weber this summer can anyone point me in the right direction on where to get/order a kit? I live in washington state. Thanks.
March 2, 201214 yr Don't buy the kit. Get the carb, adapter plate, and filter. That's all you need. GD
March 2, 201214 yr Author I see. I'm sure I can figure out where to get the carb, but where do you get the adapter? also, I want the 32/36 DGEV carb right? Edited March 2, 201214 yr by Seantheimpaler
March 2, 201214 yr Yes.. you can get the parts or the kit from carbsunlimited they are local and online
March 2, 201214 yr The carbs are online for $199 with free shipping. Found a couple places that list that price. The adaptor you can get from any Redline dealer for $35 to $40. Air filter can be had from Redline and EMPI - about $20. The kit has a worthless instruction sheet and a cable bracket that doesn't work. Not worth the extra $60 that's for sure. GD
March 2, 201214 yr Agreed. Besides, there are better instructions here on about 6 different threads that I have found recently ( in the last week)
June 10, 201213 yr Can you post these links to the weber instal threads. I have been searching with no luck. Trying to figure out how to hook up the throttle linkage Ken
June 10, 201213 yr Just ordered an adaptor plate from Shawn... You should go through him, supporting his site, RetroRoo, helps out the USMB!
June 10, 201213 yr Can you post these links to the weber instal threads. I have been searching with no luck. ... ~► http://www.ultimatesubaru.org/forum/showthread.php?t=74206 The above posted link belongs to the Instal procedure and More Ideas for the EA82, the Main Difference between the EA82 and the EA81 could be the Adaptor Plate. Kind Regards.
