5 lug conversion candidates help
I looked in the archives and found little about what parts from what cars are needed to make this conversion work. I've herd that you can use XT6 parts and thats seems to be the most popular, but then I stumbled upon a thread that someone used impreza parts for the conversion minus the e-brake. So if that's the case couldn't I use parts from a 92 and newer legacy? Any help with a parts list to do this swap and what parts from what cars work best would be great. thanks. Ian in Monroe, Washington
We can try! I personally don't see a reason why they wouldn't. My concern would be would the ball joint work with the legacy spindle. I say lets give it a go!
Hey subarutex
I've been drulling over your car and its what started my need for the conversion. What parts did you use?
I used...
Front: xt6 lower arms, xt6 ball joint, xt6 spindle, xt6 rotor and caliper, GC8 struts, stock springs
Rear: xt6 backing backing plate, xt6 rotor
Now, when I did the conversion, i test fitted some Impreza parts, unfortunately, they weren't mine, so they didn't go on the car :-/ Yet!
I'm not sure about this, but I believe that I am the first to have successfully done this conversion in the USA (see my web site), but I was probably not the first to think about it. I noticed that shortly after I had done it, there were several more people who accomplished the task. Since then I have done some more investigation. Since Tex lives close to me, and I knew he was thinking of doing the conversion, I asked him to test some of my ideas. The test was to see if Impreza and Legacy parts would work for part of this conversion. I let him borrow the complete front assembly (strut, knuckle, and axle) from an Impreza, it fit perfectly. I would suggest using the Impreza parts because I know that the Impreza axle is only 4mm longer then the EA82 axle, but I never checked the Legacy's axle length. If the Legacy's axle is the same as the Impreza, then those parts would work also.
Known parts that will work and are currently on a car with a conversion.
Front:
XT6 struts (2WD or 4WD)
XT6 knuckles
XT6 axles
XT6 lower arms
XT6 ball joints
XT6 tie rod ends
XT6 front calipers
XT6 front discs
XT6 front hubs
XT6 front backing plates
Impreza struts
Impreza knuckles
Impreza axles
Impreza ball joints
Impreza tie rod ends
Impreza front discs
Impreza front hubs
Impreza front backing plates
Legacy struts
So, the main parts that are needed from the XT6 to make this work are the lower arms and the front calipers (they will bolt to an Impreza assembly).
Rear: Only XT6 4WD parts here
XT6 rear hubs
XT6 rear backing plates
XT6 rear discs
The rear calipers off the EA82 are the same as the rear calipers off a XT6.
I'm pretty sure that if the Legacy axles are the same as the Impreza's, then all the parts that I names from an Impreza would work from a Legacy.
XT6 rear hubs
XT6 rear discs
Ahh...crap...the parts I've bought are all from a 2WD XT6...which parts won't work from the 2WD (front and rear) and what is different about them?
All the front parts will work, all the rear parts won't. The rear attach to a spindle, not an axle. I've heard that the backing plate off of a 2WD will work, but you need to enlargen the hole in the center where it attached to the rear hub.
On a slightly different note,,,Has anyone succesfully used the Imprezza front struts on the XT6 Knuckle? I just test fitted one the other day but the Imp has the cam bolt set-up for camber adjustment. I was going to have the spindles redrilled a bit to allow the full function of the camber adjustment. For now I'm just running the XT6 stock strut.
PS. Anybody know which Strut to use in the rear of an AWD XT6 when converting from air to conventional suspension? The XT6 2WD Rears I used make it sit rump roast end high. Looks pretty mean but hard to park.LOL
If you are doing a 5 lug conversion on a 2wd ea82 wagon with drums on the rear and you have a 2wd XT-6 parts car with the discs can you use all the XT-6 rear suspension and brake stuff and put it on the wagon? (XT-6 has lower control arms with a sway bar i'd like to use) It all looks the same except the XT-6 rear control arms don't have the pads for the rear snubbers to contact. (The XT-6 nas no snubbers)
Has anyone ever bothered to convert a 2wd wagon? Can you guys help me out on this? Ive got all the parts I just need some direction.
ByTheSea, if you look at Tex's second post here, he stated that he used a GC8 strut. GC8 is a common (but mis-used) term for an Impreza. The XT6 and the EA82s don't have struts in the rear, they use coil over shock absorbers, there are several different spring rating for those shocks.
do we have a good 5 lug conversion thread in the archives or USRM yet? this one would do nicely if we don't.. or maybe combine this and whatever else we have...?
And for some reason or another, either I did something wrong, or my wagon is weird, because nobody else has had the problem I had. I had to re-drill my front crossmember because the XT6 uses a bigger bolt to attach the control arm to the crossmember than what my wagon had.
Does anyone know if an XT6 crossmember would bolt into my wagon??? It's either that or do some grinding and hammering on either the control arm or the crossmember, and I've never been a big fan of grinding and hammering suspension components.
  • 5 weeks later...
I'm interested in the XT6 crossmember question as well.. I'm thinking about doing this to my wagon this summer and I'll have access to a crossmember as well.
I have seen nothing that would tell me that the XT6 crossmember would not bolt to an EA82 car, so go for it and let us know what happens. I'm more curious about an Impreza fitting, but I think it is a little too wide. But heck, maybe spread the rails, then weld that attach point for the Impreza lower arm, then you would have better adjustable front suspension.
my setup uses ea82 lower control arms, drilled out to accept the xt ball joint. i did this because my xt control arm had a the bolt seized in the bushing
i used the xt6 knuckle, caliper, and tie-rods. i used LEGACY struts, with ea82 spring and ea82 strut cap. the legacy strut knuckle attatchment had to be widened for the xt knuckle, and the holes are bigger than the xt bolts. i used the xt bolts.
i was going to use the legacy axles, but i couldnt get the nuts off.
i used the legacy ball joint to replace one that was bad on the xt knuckle, it fits the same
