My 1995 Impreza
  • Replies 56
  • Views 8.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • crazyman03
    crazyman03
    dang! wish my welds looked that good! haha! I imagine my technique would be better if i welded more - Meh :-/   Anyway, got back under there to patch up a few leaks that i saw earlier. Some condens
  • crazyman03
    crazyman03
    -Justin
  • you have the same car as me i love it heres how mine sits
Ok, a bit more time to post now. Here's kinda how it went in order..
quick mockup on the ground
Up on the car, right before tacking the welds and finishing it up, no, the bundgee coard is NOT sticking around, i did install a hanger - top left where the OE one would be ;-)
after it all:
-Justin
Edited by crazyman03
muffler needs to be up higher, out of sight, looks good tho
+1 Agreed, mines kinda tucked up... I love starting it and watching people "casually" walking by it and looking under the car haha...
I was trying for a bit tucked up but somewhere between the tack welds and pulling it down to finish it kinda shifted. That, and it already kinda sat funky up there. the angle going under the axles was kinda weird and would've rubbed. I might pull it back down and attempt to bend the angle a bit and see where that gets me. I also dont like the stupid angle that most 'roo's (and stupid hondas) do with it all cocked upword. Granted, i dont have a fart can.. but still not fond of being able to see the muffler.
-Justin
yea, it will shift.
when i did the exhaust on the RX, i had everything super tight, pulled it down and welded it, now i have plenty of clearance everywhere EXCEPT the rear hanger, which it now smacks so i have to jump under there and cut it.
i'm definatly a fan of things being tucked up.
Anyway, got back under there to patch up a few leaks that i saw earlier. Some condensation was leaking through the welds. I also got the muffler to go up a bit higher and painted the exhaust black - maybe it would bug me less if i didnt see it so easy.
I think i like it more..
vid before i did the work today. JusZek asked for it
-Justin
picture.php?albumid=341&pictureid=2681
I did the same thing in the DL, waaaaay too bright at night
Thank you for the Video!
....vid before i did the work today. JesZek asked for it
-Justin
I Really Like your Nice Impreza Wagon and all the Mods You've done!  Thumbup.jpg
About the extremly brilliant Dashboard after Led Swap, Have you Used the Dimmer Knob ...  :ph34r: ... ?
Kind Regards.
Edited by Loyale 2.7 Turbo
Resistors young patawon
Yep...
If you installed LED Bulbs instead the incandescent T-10 and T-5 Behind the instrument cluster, you'll need to install a single Resistor Behind the the Power Input (12V +) just before it accesses the Dimmer Knob.
Kind Regards.
I'm thinking i'm sitting a bit higher on the front :-/ Thinking in need to bring the back up too *teeeheeehee* (the axles arent really angled much on the rears). The rear tophats on the OBW struts i have dont come off for some reason. I was trying to put the tophats that had my "lift" done, i couldnt get the OBW tophats off.. and i threw away the spring tops from my old Impy struts :-/
-Justin
Well.. i unplugged the LEDs on the dash for now. I am thinking about tinting the plastic and seeing where that gets me.. i don't want it too dark but id like the whole "new age" look ;-)
anyway, an update.. i got a new amp!
well, CB linear amp lol!!
-Justin
  • 2 weeks later...
