March 19, 201313 yr i have a shitload of subi parts floating around and im going threw them and selling some off more parts will be added later but here is a start like i said these are all for ea71 engines may work on the later ea81 but i make no promises of that will ship at buyers expense located in LaPine oregon later air cleaner assembly for use on carbs with the traditional center stud has surface rust but nothing a little sanding and paint cant fix $20+ shipping early clamp style air cleaner assembly the threaded rod broke will need to be drilled and tapped with a new bolt $15+shipping later ea71 intake manifold complete with emissons equipment and hoses no egr i took it to use on my engine $40+shipping air injection tubing "spider" in good shape no cracks in the tubing threads are good and was removed with a proper line wrench so the heads arent all screwed up $20+shipping later ea71 cylinder heads in good shape all valves seat correctly but due to blown head gaskets at some point in this engines life there is surface rust in the combustion chamber need to be cleaned up i dont really want to part with these but if i might be tempted to part with them for $150+ shipping (might be a little high) ea71 valve covers i have 3 spares all in similar condition paint could use a polish on all $15+shipping each all prices are best offer may also consider trades for things like a grant wheel adapter for a first gen wagon Edited March 19, 201313 yr by bonvo
April 1, 201313 yr Author unfortunatly not a clue it has the full internal coolent passages instead of the cross over pipe so my guess would be a later engine near the end of the 1600 life span
April 1, 201313 yr Author adding these to the list BRAND NEW main bearing set ordered these for my rebuild and my parts supplier says there for an early ea71 main things to take into account is that the thrust bearings are identical they do not have the lock tabs offset as apparently the later ones do but they are brand new i still have the original box only thing i dont have is the shrink wrap just looking to get what i paid of them $30.00 + shipping the lock tabs i mentioned above again these are BRAND NEW BEARINGS someone has to need these things
April 25, 201312 yr Author bump will consider trades for ;parts i need like a hamster wheel ans a lower right side tail light lens for a 78 goon
May 27, 201312 yr Author bump also looking to let go of the 2 short blocks i currently have someone must need these parts
June 5, 201312 yr You wouldn't happen to have a pitch stop rod, goes from the firewall to the top of the bell housing? i can't seem to locate one...
July 10, 201312 yr Hey Bonvo, do you still have that later '71 air intake? Someone, prior to my ownership decided that there wasn't enough air getting in and they decided to perforate the outer housing and it looks similar to a cheese grater...
September 19, 201312 yr Author pms sent to all of you guys again sorry for the delay i have been busy and away from the computer lately
