May 26, 201312 yr 81 definatly shouldn't have an ECM. Wrong. California cars had ECMs and O2 sensors..
May 26, 201312 yr ^thats what i thought have torn into almost to many of these second gens(around 30) for parts that i needed/need for my brat which can have a ecm(its wired to have one in the harness) and my 83 turbo wagon which has one. Edited May 26, 201312 yr by turbosubarubrat
May 26, 201312 yr Wrong. California cars had ECMs and O2 sensors.. In 81? I'm sorry but I've never seen any 81 with an ECM in any brand except cadilac. I can look this up and I think I will, I could beleive 83, but not 81.
May 26, 201312 yr so i take the signal from light harness to turn on a realy one for 4 highs and one for 4 lows give the realy power feed right off the alt batt termanal this will give you 4 high beams and 4 low beams with clean power from alt giving the headlights power before anything else. On my 84 i have 4 x 100 watts on high and 4x65 watts on low at 14.20 volts at 100 amps and they are realy bright get high beamed everywere i go but i can see
June 10, 201312 yr Author So I found out that one of my wires that went to a spark plug had been corroded, so it was shorting or something and melting the wire practically. I got a new wire on, so I think that the bad wire was sapping juice and that's why the car was doing so many weird things.
