distraction's
  • Replies 76
  • Views 14k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • well im going 2.5 body 4" suspension 14" wheels 225/85/r14 tsl   (kinda funny found my wheels at the wrecking yard had them for a few days went to  drill them out and seen some one had marked 3 of t
  • Got some differnt tire Think they might get traction Only 27" tall 27x11r14
  • well no updates ive been staying at valley medical center for almost a month now but wife is released and my new daughter hope marie lentz should be released this week!!!! then ill get back on the soo
Posted Images
Frustrated with buuilding crosmember mout for the tanny played with some other stuff
Tryinng to figur out placemennt and if i have room for the 20 gallon fuel tannk (was 15$ at the scrap yard ) winch 2x group 24 batterys and a back seat would like to find 4x subaru brat seats just need bare seat and 2 with just handles
Thought IDE post some buggys I found that are like the one I'm building
Think I need to move the shock forward about 4" as its a bit soft the way it sits and there is more room for travel once it has weight on it
Any one have any thoughts?
Edited by apintonut
  • 1 month later...
Wow I guess I'm just posting for the hell of it but I'm working 3jobs right now no time to work on it but next day I have I'm going to pull it out of the garage and clean up around it
I like what your doing,  looks like something I would build, want to help where I can, on the rear spring set it up more vertical then try it out once all the weight is on the car, those rear axles are limited on there travel, work within there travel and you will be ok,  when do you plan to have it going?  any events or outings your trying to make?
Edited by Scott in Bellingham
I wanna have it done in time Family outing with about 300 of my family members and wcss and would like to go play at some hill climb in the sxs class
Edited by apintonut
  • 2 weeks later...
Well not much of a up date. However the radiator is in
I guess im out of alowed disk space to upload pic's
Edited by apintonut
Looks sweet! i would love to do something like this... just need alittle more experience with welding...
The welder i have sucks i wish i had money for a better one . Im looking at the bigest wire feed harbor frieght sells its better than my 500$ lincon for only 289$
its still just being tacked together for the mock up then it all comes apart gets final weld paint then back together for a finsh
Save your money and sell your current Lincoln for a better one....or Miller, Hobart.......anyhting but harbor freight.
Harbor freight welder will break within a year of even moderate use........Cheap hoses will get punctured......wire feed jams....stops working.....and they are not repairable.......too much cheap china parts not interchangable with "industry standard" .......You will regret it.
prep prep prep. That welder will do fine if the welder behind it will take more time to learn how to manipulate the puddle. More heat , less speed until you get the hang of it. Just because it doesna have gas doesna mean it sucks. I Welded a codswallop ton of stuff with flux core before I got a bottle. I have a Lincoln promig 140 . Flux core is actually hotter wire than solid wire. Taking your time can really help.
If you really want to buy something from Harbor Freight , then I suggest a welding helmet that you don't have to fight. holding the lens type is really unhelpful. you need to be able to support your hand and get proper positioning , and movement.
cheers
Edited by monstaru
  • 3 months later...
Ok have radiator in and see brackets tempt in have 6the lugs drilled hid lights built but i do have 3the jobs a wife & baby and a 93loyale im trying to get on the road for winter as my jeep dosnt wana live soo.....
  • 8 months later...
Look what got un buried out of garage
Edited by apintonut
Note the shock angle is to sloped so it was to soft moved the up today and it may be to stiff now the CV are to much angle but I'm going to run with it for now and spend another 150$ on shocks if must or move them back at the last second if I must
