March 15, 201412 yr Author So last night I put the EUL headers I built a while back for the Green BRAT on the red BRAT and modified it a bit. it is running 2 inch pipe from block all the way back with two glasspacks. Its so quiet at idle now but has a nice rumble when you get on it! Sorry for the horrible quality video.http://vimeo.com/89166580 Edited March 15, 201412 yr by Kevint143
March 19, 201412 yr Author 1536636_518513448257204_1517574074_n by Kevin Talley, on Flickr took the BRAT out for a little drive to do some mountain biking and stopped to snap a pic.
March 25, 201412 yr Author Untitled by Kevin Talley, on Flickr So last night I couldn't sleep and my daughter wanted to hang so I let her stay up late and help me swap the intake manifold from green brat since it had my weber on it and put it on the red brat. In the process I am not confident I hooked my vacuum lines up right. Can someone snap a photo of your weber set up for all the vacuum lines? Edited March 25, 201412 yr by Kevint143
March 27, 201412 yr very cool. i like it in red, that color works nicely on that brat. i think i want a 1st gen when i finish my current brat, lol.
March 29, 201412 yr Author So I have been struggling the past few nights. I put the weber on and now I can't get the car to start. I have fuel its getting spark but I think my timing is way off. The car will crank but won't start I have gone through all the processes I can think of to check for fuel and spark and they have all been positive. I can't time it until it starts does anyone have any suggestions?
March 29, 201412 yr Same thing happened to me. Back to basics1.) set engine to TDC, 2.) align dist gear and shaft and lower into position 3.) confirm rotor is pointing at #1 4.)recheck gaps, 5.) run plug wires. 6.) check coil is hooked up properly (if not replace burnt fuse). I'll send you a pic of vacuum lines but should just be vac advance and PCV (into filter) other lines are coolant. Edited March 29, 201412 yr by tundrabrat
March 30, 201412 yr The hood scoop looks really good, i might have to do one on my loyale, non functional of course but it'd look good!
March 30, 201412 yr Author That's exactly what I ended up doing tundra and got it started first turn of the key. At tdc I was at #2 on cap/rotor adjusted that and we are good to go! But was test driving it and blew a coolant hose so off to the parts store for a new one!
March 30, 201412 yr So last night I put the EUL headers I built a while back for the Green BRAT on the red BRAT and modified it a bit. it is running 2 inch pipe from block all the way back with two glasspacks. Its so quiet at idle now but has a nice rumble when you get on it! Sorry for the horrible quality video.http://vimeo.com/89166580 This sounds amazing. Got any more info on this custom EUL header you made? If I can get the Brat to sound like my sti, it would make me a happy camper. Edited March 30, 201412 yr by spicypeanut
March 31, 201412 yr Man i dig the 1st gens good looking rigs bud....guess ill have to start on one when im done with the 86! the biggest problem is finding space for all my rigs lol. Buck
April 8, 201411 yr Author Untitled by Kevin Talley, on Flickr Put the wheels off the 79 onto this one because the tires are brand new. Not sure how I feel about the white wheels.
April 8, 201411 yr Author http://vimeo.com/91383158 quick video of the latest exhaust set up. This was a cold start after sitting for two days. I didn't let it warm up because I was just parking it on the street and didn't want to make the garage smell like brat exhaust. I can't stop tweaking with it ha...going to throw something else together soon Edited April 8, 201411 yr by Kevint143
September 1, 201411 yr Mad ride, I love it. It's sad that there aren't a single one of this model in my country
September 3, 201411 yr Author Thanks I think I will keep sitting on it for a while. Finish my swap on the 79 and figure out what I want to do with this
