April 30, 200421 yr If I wanted to lower an EA82, which springs and dampers would I use? I seem to remember that XT springs and struts would lower an EA82, but how much?
April 30, 200421 yr do a search. me and the scooby had a thread a few months ago and someone posted a good factory spec sheet of all the suspension components on EA82 cars
April 30, 200421 yr How much it lowers it depends on where you are starting from. If you have a 4wd wagon, it will bring it down about 1 3/4 inch
April 30, 200421 yr XT front struts/springs will bring it down aeounds 2 inches...the rear springs is what you want, as the XT struts for the rear will actually raise you up. The springs will bring it down 1/2 to 1 inch.
April 30, 200421 yr Author Ok, now the question I really want answered. What will these to the front of an EA81? I know RX springs will raise the front about 1", so the XT springs will take away that one inch, then lower it 3/4 of an inch below the stock height? Probably the net gain on my car will be less because it is on a turbo wagon and they're lower already. Would I be able to use EA82 struts on my EA81?
March 5, 200818 yr XT front struts/springs will bring it down aeounds 2 inches...the rear springs is what you want, as the XT struts for the rear will actually raise you up. The springs will bring it down 1/2 to 1 inch. eureka xt springs on 4wd wagon struts will lower it 1 inch is this what im hearing. Ben
July 16, 200817 yr eureka xt springs on 4wd wagon struts will lower it 1 inch is this what im hearing. Ben bump for my answer please:grin:
July 17, 200817 yr XT springs WILL lower your EA82, but by how much, I'm not sure. well i just found this out so bear with me. the xt6 springs and struts will lower about 2 inches but its the rear where it gets confuseing. I know flip the top hats but i didnt hear about useing xt rear springs. Which strut would you use then for the back. Ben
